#201
Posted 22 January 2013 - 02:53 PM
Need to follow directions to the letter.
#202
Posted 22 January 2013 - 03:01 PM
#203
Posted 22 January 2013 - 03:04 PM
except I did. I did extract the whole zip and ran it. Should I try running the bat as admin prvi in Win 7?
Yes, sorry. I assumed you were doing that. It won't work otherwise.
#204
Posted 22 January 2013 - 03:15 PM
#205
Posted 22 January 2013 - 03:26 PM
jcarlosfox okay I have done all that, still no JB. You may have got to my question before seeing my edit. Do I need to download the ROM separately or should it have come with the ZIP? I have SafeStrap installed and I ran the exploit w/ Admin priv already. I am still getting the same output I put before.
What version of Safestrap did you install?
When you boot, do you get the Safestrap menu? (If so, you are rooted.)
Have you installed Voodoo? What result?
My knowledge is limited, but I am sure the answer is here. If you read this thread the next step is likely a factory reset, DO NOT allow Smart Actions to update, and run the exploit again.
#206
Posted 22 January 2013 - 03:40 PM
#207
Posted 22 January 2013 - 03:45 PM
Checking all that now. I know that SS is 3.0.5. Haven't installed Voodoo, where do I get it? I know for sure I have Smart Actions set up correctly.
Voodoo is in the play store.
#208
Posted 22 January 2013 - 03:49 PM
Are you on JB or ICS? Someone is had that same issue and they were trying to root JB but still on ICS
#209
Posted 22 January 2013 - 03:57 PM
#210
Posted 22 January 2013 - 03:58 PM
#211
Posted 22 January 2013 - 05:22 PM
#212
Posted 22 January 2013 - 05:24 PM
I thought this was to get from ICS to JB?
Nope. This is ONLY for. JB. Just like it says in the caption.
#213
Posted 22 January 2013 - 05:25 PM
This the thread you want:
- jcarlosfox likes this
#214
Posted 22 January 2013 - 09:17 PM
#215
Posted 22 January 2013 - 09:29 PM
hey guys im still having trouble rooting... on the step where is says "Select get started" i don't have that option on my razr maxx... just a plus sign to create a new rule... ugh.. any suggestions? I dont have a charge only option either camer, media, or mass storage
Make sure you are on JB.
Find the rule it wants you to use.
Change something.
Save it.
Change it back.
Save it.
Follow the rest of the instructions. It is what I did. It worked the second time I tried it.
#216
Posted 23 January 2013 - 01:27 AM
#217
Posted 23 January 2013 - 08:10 AM
I only got up to page four by the time I solved this, but I actually had to update Smart Actions, and then go back and uninstall all updates for this all to work. Sounds odd, but I hope it can help someone!
Thanks for letting people know =]
It might be a good idea to add this to the OP, or at least the version of the most current of Smart Actions :-)
Sent from my RAZR MAXX HD using Tapatalk HD
- arch7angels likes this
#218
Posted 23 January 2013 - 05:10 PM
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Phase one...
link failed Permission denied
[*] Rebooting device...
[*] Phase two...
/system/bin/sh: cat: /data/data/com.motorola.contextual.fw/files/DataClearJarDex.jar: Permission denied
[*] 2. Select Get Started.
[*] 3. Select Battery Saver.
[*] 4. Select Save.
[*] 5. Press the Home button.
197 KB/s (3477 bytes in 0.017s)
/system/bin/sh: can't create /data/data/com.motorola.contextual.fw/files/DataClearJarDex.jar: Permission denied
/system/bin/sh: can't create /data/dontpanic/apanic_console: Permission denied
[*] Phase four...
1819 KB/s (91992 bytes in 0.049s)
2649 KB/s (1867568 bytes in 0.688s)
4348 KB/s (574184 bytes in 0.128s)
4135 KB/s (63838 bytes in 0.015s)
[*] Cleaning up...
/system/bin/sh: su: not found
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
#219
Posted 23 January 2013 - 05:13 PM
:Can someone please help? I'm trying to run this from my mac to unlock my Razr Maxx HD. This is what I get:
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] 4. Select Save.
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
This is for the OG Razr/Max (XT912) not the HD
Sent from my DROID RAZR
#220
Posted 23 January 2013 - 05:18 PM
It is right in the instructions in the OP, and the following is in the output in the most recent question:
] Note: this will not work on RAZR HD, Razr M, etc.
Why is it easier to post to a forum than to read the instructions and the output on the screen?
Not sure if we are helping people with reading compression or their phones! :-)
