Do I need to find and install Safestrap, or is it already there?
#181
Posted 20 January 2013 - 06:14 PM
#182
Posted 20 January 2013 - 06:15 PM
- Vooyah likes this
#183
Posted 20 January 2013 - 06:18 PM
supersu was the one installed on mines.
Sent from my DROID RAZR MAXX using Tapatalk2
Thanks! Removed SuperUser, and started over with Voodoo just in case!
THANKS!
#184
Posted 20 January 2013 - 10:03 PM
I followed the directions to a "T" using my Lenovo laptop (company issued). I had no luck. After returning home from my business trip I decided to try again with my home laptop.
I downloaded the fresh Moto driver, used the correct USB cable, followed all directions, and success!!
Now if I can just get this hot spot working correctly
#185
Posted 21 January 2013 - 06:46 AM
<p> </p>
<p> </p>
<p> </p>
<div>
<div>[*]</div>
<div>[*] Razr Blade: Motorola Droid Razr 4.1 Root Exploit (Windows version)</div>
<div>[*] by Dan Rosenberg (@djrbliss)</div>
<div>[*]</div>
<div>[*] Thanks to p3droid for assistance in testing.</div>
<div>[*]</div>
<div>[*] Note: this will not work on Razr HD, Razr M, etc.</div>
<div>[*]</div>
<div>[*] Before continuing, ensure USB debugging is enabled, that you</div>
<div>[*] have the latest Motorola drivers installed, and that your phone</div>
<div>[*] is connected via USB.</div>
<div>[*]</div>
<div>[*] Please carefully follow any instructions provided in the exploit.</div>
<div>[*]</div>
<div>[*] Press enter to root your phone...</div>
<div>Press any key to continue . . .</div>
<div>[*]</div>
<div>[*] Waiting for device...</div>
<div>[*] Device found.</div>
<div>[*] Phase one...</div>
<div>link failed No such file or directory</div>
<div>[*] Rebooting device...</div>
<div>[*] Waiting for phone to reboot.</div>
<div>[*] Phase two...</div>
<div>/data/data/com.motorola.contextual.fw/files/DataClearJarDex.jar: No such file or</div>
<div> directory</div>
<div>[*] Complete the following steps on your device:</div>
<div>[*] 1. Open the Smart Actions application.</div>
<div>[*] 2. Select "Get Started".</div>
<div>[*] 3. Select "Battery Saver".</div>
<div>[*] 4. Select "Save".</div>
<div>[*] 5. Press the Home button.</div>
<div>[*]</div>
<div>[*] Press enter here once you have completed the above steps.</div>
<div>308 KB/s (3477 bytes in 0.011s)</div>
<div>/system/bin/sh: cannot create /data/data/com.motorola.contextual.fw/files/DataCl</div>
<div>earJarDex.jar: No such file or directory</div>
<div>[*] Phase three (this will take a minute)...</div>
<div>failed on '/data/logger' - Permission denied</div>
<div>mkdir failed for /data/logger, File exists</div>
<div>Unable to chmod /data/logger: Operation not permitted</div>
<div>link failed File exists</div>
<div>[*] Phase four...</div>
<div>76 KB/s (91992 bytes in 1.174s)</div>
<div>1350 KB/s (1867568 bytes in 1.350s)</div>
<div>1495 KB/s (574184 bytes in 0.375s)</div>
<div>1298 KB/s (63838 bytes in 0.048s)</div>
<div>[*] Cleaning up...</div>
<div>/system/bin/sh: su: not found</div>
<div>[*] Rebooting...</div>
<div>[*] Exploit complete!</div>
<div>[*] Press any key to exit.</div>
<div> </div>
<div> </div>
<div>any light to what i am doing wrong i would greatly appreciate!</div>
</div>
<div> </div>
#186
Posted 21 January 2013 - 01:50 PM
#187
Posted 21 January 2013 - 02:24 PM
Ok so im really new to rooting, like this will be my first try, is there any preperations i need to do to make sure this goes smoothly and doesnt brick my phone. or is this file pretty much a one and done kind of root.
Just follow instructions. There is nothing this process could do to brick your phone. Worst case, it fails. Best case you are rooted.
#188
Posted 21 January 2013 - 02:58 PM
ok how do you know if it worked?? i ran the program and i got this
'adb' is not recognized as an internal or external command,
operable program or batch file.
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
#189
Posted 21 January 2013 - 03:02 PM
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
It did not work.
You need to make sure you are on an original Droid Razr or Razr Maxx. Running Jelly Bean, and follow all pre-instructions.
#190
Posted 21 January 2013 - 03:03 PM
#191
Posted 21 January 2013 - 03:31 PM
You need to extract the zip file to your desktop and then run the bat file. Looks like you are just opening the zip and trying to run it without extracting it. That's why Adb is not recognized
It did not work.
Still have no idea if it worked, like i said im really new to this but this is what i got after restoring factory settings and updating smart actions,
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
#192
Posted 21 January 2013 - 03:36 PM
#193
Posted 21 January 2013 - 03:51 PM
[*] Device found.
[*] Phase one...
[*] Phase two...
[*] Phase four...
[*] Cleaning up...
[*] Rebooting...
Well, we can't help you if you can't or won't read and follow basic instructions.
1) You need to download and EXTRACT the entire Zip file. You CANNOT simply run the batch file without the related files. The FIRST error message in the output you posted shows you have not followed the first part of what is needed.
2) Once you have properly extracted the exploit, then run the batch file AFTER you have set up your phone exactly as instructed.
If you can't set up your phone to run the exploit then maybe you don't need root. This is basic stuff and the instructions are pretty simple
3) Once the phone is set and you run the exploit you should read the output. If it worked, it will tell you. You should download and install Voodoo Root Keeper too. It will also confirm if you are rooted.
Bottom line, this is easy, and there are a few of us following along to help you along. I'm not sure how much more we can offer short of a personal visit. :-)
#194
Posted 21 January 2013 - 03:55 PM
my bad guys i posted an older try from earlier today, i posted the same outcome twice by accident this is what happened last time i ran it
[*] Device found.
[*] Phase one...
[*] Phase two...
directory
679 KB/s (3477 bytes in 0.005s)
[*] Phase four...
1197 KB/s (91992 bytes in 0.075s)
2390 KB/s (1867568 bytes in 0.763s)
3461 KB/s (574184 bytes in 0.162s)
3280 KB/s (63838 bytes in 0.019s)
[*] Cleaning up...
[*] Rebooting...
#195
Posted 21 January 2013 - 04:08 PM
#196
Posted 22 January 2013 - 11:42 AM
#197
Posted 22 January 2013 - 11:52 AM
Any ETA on when this program will work with RAZR MAXX HD phones?
[Xt926]#entry124671
How To Root Your Hd [Xt926]
#198
Posted 22 January 2013 - 12:01 PM
I have superuser installed on mine. Not a trace of supersu.supersu was the one installed on mines.
Sent from my Droid Razr Maxx on 4.1.2 with Tapatalk2.
#199
Posted 22 January 2013 - 12:19 PM
#200
Posted 22 January 2013 - 02:49 PM
[*] Device found.
[*] Phase one...
[*] Phase two...
directory
1111 KB/s (3477 bytes in 0.003s)
[*] Phase four...
204 KB/s (91992 bytes in 0.439s)
3001 KB/s (1867568 bytes in 0.607s)
2966 KB/s (574184 bytes in 0.189s)
3666 KB/s (63838 bytes in 0.017s)
[*] Cleaning up...
[*] Rebooting...
What do I do next or am I doing something wrong?
Ed S.
