i need a solution for my xt912 please!
Posted 15 May 2015 - 06:14 AM
Posted 15 May 2015 - 06:25 AM
I flashed my xt912 with rsd lite and i dont know what happen but my phone after that when the phone boot to setup wizard screen is still rebooting every 3 o 5 minutes And I can't bypass the setup.........finding i found that my phone is baseband unknown (I can enter to settings).....then i tryed flashing the radio for separate in fastboot......do anything good like a work nice (enter to recovery and flash the radio) I see the process.......but when the phone boot to the setup wizard again boot whithout baseband and not show the SIM icon to te top to the left on shows the signal bar......and no radio or baseband installed.....I'm crazy I dont know what happen and I don't know what I can do.....HELP ME PLEASE!!! I was reading a post say the PDS partition is corrupted I need to know if it I format this partition I get back my phone fully functional??? I NEED YOUR HELP
What was the file name of the fxz you flashed. You need to make sure it was for you area and carrier. If it was the correct file then the sim may be bad and needs to be replaced. Try shutting the phone off and removing the sim card. Reboot the phone and let fully boot up and give you the no sim installed error again. Shut it back off and re-insert the sim and reboot.
- rickw and augusto001 like this
Posted 15 May 2015 - 07:29 AM
Who is your provider?
Posted 15 May 2015 - 10:24 AM
. I no got SIM card installed on my phone......and i should see the SIM card not installed icon on the top.......but this is not my problem....my problem is I cannot flash radio on my device......when I flashed the fxz files with rsd lite or APfastboot separately whithout rsd lite.....do all processes good but when the phone boot to the os I enter to settings (I can enter to setting of setup wizard screen) and go to info device and there I show say "BASEBAND UNKNOWN" my device is not picking the radio. Thanks for reply me!What was the file name of the fxz you flashed. You need to make sure it was for you area and carrier. If it was the correct file then the sim may be bad and needs to be replaced. Try shutting the phone off and removing the sim card. Reboot the phone and let fully boot up and give you the no sim installed error again. Shut it back off and re-insert the sim and reboot.
Posted 15 May 2015 - 10:29 AM
I use a SIM of Orange DR UMTS 1800mhz (band 3) is 3g with this company.....but the problem is the phone when I flash with rsd lite when boot boot with "baseband unknown" I think when I can fix this my phone leave to reboot every 3 minutes.....I need really help for fix this!Who is your provider?
Posted 15 May 2015 - 01:30 PM
Posted 15 May 2015 - 02:42 PM
What was the file name you used to flash your phone?
Posted 15 May 2015 - 02:43 PM
Help.....i cant install radio on my xt912 it's "BASEBAND UNKNOWN" i tryed rsd lite flashing full stock....for fastboot separately images and NO FIX THE BASEBAND...I TRYED TOO MATTS JB TOOL and no work for restore baseband AND when boot to OS is "BASEBAND UNKNOWN" every time I flashed and too is still rebooting every 3 mins less o more.......I NEED REALLY HELP.....before I intented restore my phone with FXZ file and RSD LITE was working fine......anybody help me!!!
replied to you in the other thread
Also here is a link with files for your phone and area.
Posted 15 May 2015 - 03:20 PM
Posted 15 May 2015 - 03:39 PM
No Men this not work for me i tryed this and others methods like house of moto and jb Matt's tool and nothing restore my baseband I think on a real problem!replied to you in the other thread
Posted 15 May 2015 - 03:42 PM
I flashed this file ***VRZ_XT912_9.8.2O-72_VZW-16-5_CFC.xml*** with differents methods and anyone worked for restore back my baseband it's still "UNKNOWN BASEBAND" THANKS. BUT I NEED OTHER THING FOR FIX IT!!!What was the file name you used to flash your phone?
Posted 15 May 2015 - 03:49 PM
I will look and see if there is a fix and get back to you.
Posted 15 May 2015 - 03:53 PM
yes sir I NEED OTHER fix definitely!!! Any solution you can find i would be very grateful to you!!I will look and see if there is a fix and get back to you.
Posted 15 May 2015 - 04:26 PM
This is the last utility I have found here and other forums. I too have seen quite a few that have said the partition was corrupt and had to have their phones replaced. I hope that isn't your case. If you have tried this version of matts utility then I am out of ideas. Let me know what happens.
Posted 15 May 2015 - 05:43 PM
yes sir i tried flash with this tool but this no fix mi phone problem "BASEBAND UNKNOWN" and is still reboot every 2 minutes.......before I flashed the phone the first time that I did it was 100% functional.......does not exist any fixing for this??? I cant flash radio......I think the radio partition is missed or corrupted.......I'm finding but no find nothing solid!!!....... I was reading on other post outside that can be the ***PDS partition*** is corrupt......find about this....to see if you have more lucky than me!!! Thanks for reply!!!This is the last utility I have found here and other forums. I too have seen quite a few that have said the partition was corrupt and had to have their phones replaced. I hope that isn't your case. If you have tried this version of matts utility then I am out of ideas. Let me know what happens.
Posted 15 May 2015 - 05:49 PM
The 912 is getting old and not much attention for the last couple of years. I did run on to this a few minutes ago you may want to look at it.
Posted 16 May 2015 - 07:37 AM
my phone Was unlocked before gave me this problem after I flashed......I do this when I buy this is not my problem.......until my phone its shows unknown baseband AND I can't write a radio on my phone dont will read my sim card again!!! this is the problem men!!! Believe to me!The 912 is getting old and not much attention for the last couple of years. I did run on to this a few minutes ago you may want to look at it.
Posted 16 May 2015 - 09:26 AM
if I could run apk on my phone I install it safetrap and install a custom Rom but I can't tryed anithing have to do run apk's......because I can't bypass the setup language configuration screen (the initial screen when phone boot to os) on my device!!! I only can enter to settings from this setup language configuration screen I can't run any app......and is keep rebooting every 3 minutes more or less!!! I'm not found any f*****g Solution for fix this!!!The 912 is getting old and not much attention for the last couple of years. I did run on to this a few minutes ago you may want to look at it.
Posted 16 May 2015 - 12:22 PM
I found this while searching last night. Seems that most people with this problem are being told to use rsd lite and flash back to stock. Or try a custom rom some have been able to get the reboot to stop but no luck on getting imei or baseband back. Doesn't look good.
Posted 17 May 2015 - 07:43 AM
i tryed various version of rsd lite and the baseband unknown keep like this.....I need fix for PDS partition.......I will have my phone working again!I found this while searching last night. Seems that most people with this problem are being told to use rsd lite and flash back to stock. Or try a custom rom some have been able to get the reboot to stop but no luck on getting imei or baseband back. Doesn't look good.
- spainter likes this
