Possible Hard brick Xt926
Bricked Hardbricked
40 replies to this topic
#21 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 13 May 2015 - 06:24 PM
hang on let me look at a couple things
#22 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 13 May 2015 - 06:46 PM
I have seen those errors a few times before all of those times there was a problem with the flash memory on the phone and they never did get it to flash.  That was a couple months or so ago when they started showing up.  It has gotten beyond me at this point.  Your connection and computer seems to be correct and sending the proper commands.  It seems like the memory in the phone has a problem.  If any one has an idea I would sure like to hear it.
Sorry I couldn't be of more help.
#23 SamuriHL
  • 44,375 posts
Posted 13 May 2015 - 07:36 PM
Download that and extract it to the HouseOfMoto\TOOLS directory, allowing it to overwrite everything.  Then try flashing it again.
  • spainter likes this
#24 Costa54
Costa54
  • 27 posts
Posted 14 May 2015 - 03:12 AM
that's alrught thanks for the help
no luck, it keeps failing
#25 SamuriHL
  • 44,375 posts
Posted 14 May 2015 - 03:56 AM
Then it's very possibly a hardware failure.
#26 Costa54
Costa54
  • 27 posts
Posted 14 May 2015 - 07:51 AM
alright thanks for your help but looks like its going on Ebay for parts  :violin
#27 claps1775
claps1775
  • 596 posts
Posted 15 October 2015 - 12:08 AM
What type of fix would work on my phone. I have the same phone. Been searching and posting on forum. What happen was I wanted to fry a kk custom rom. I been on jb custom for about a year. I rsdlite my phone back to oem jb. downloaded kk fine and when it was installing. phone became none responsive. I cannot turn phone on at all. All i get out of if it green led phone when pulled into the pc. pc makes the sound when usb is connected but nothing happens. green led comes on and you can hear the connect and disconnect. I would like to make this phone my back up. I am not sure why the factory cable is not working or if something is really messed up.
#28 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 15 October 2015 - 04:14 AM
Just a shot in the dark here but try hooking the phone to a ac charger for a while and see if the green light goes out and it gives you enough power in the battery to get it into fastboot mode.  The battery still has to have enough of a charge in it to boot into fastboot.  Once into fastboot mode and you don't have the qload error you can attempt to flash again. I know you were getting a factory cable from ebay since a blackhat adapter is no longer available. If you have the qload error it is toast.  With out the flashing tools which the do sell on ebay and cost about as much as a replacement phone it is sunk.
#29 claps1775
claps1775
  • 596 posts
Posted 15 October 2015 - 06:39 AM
I have let my phone sit on the charge all day. Green led goes out. The qload error. How will I know? I have looked in my device manager. I see the qload and it has a triangle at. Drivers fail to update or to browse to install manually. Flashing tools? These might be worth having....
Sent from my XT1080 using Tapatalk
#30 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 15 October 2015 - 11:23 AM
when you manually get the phone into fastboot mode (volume- + power key) to get to the menu select fastboot. Yolu will know if the qload error is there fastboot won't look the sme.  Your going to have to straighten out your drivers not working on your computer.
#31 claps1775
claps1775
  • 596 posts
Posted 15 October 2015 - 11:44 AM
My phone will not boot up.
#32 SamuriHL
  • 44,375 posts
Posted 15 October 2015 - 12:01 PM
If it's showing qhload, it's done.
  • RikRong likes this
#33 claps1775
claps1775
  • 596 posts
Posted 16 October 2015 - 05:58 AM
I have no clue if it is done or not. Screen is blank. No power only green led lights up and pc makes sound when HD Maxx is connected. That is it. So, not able to fast boot and not able to check qhload.
#34 SamuriHL
  • 44,375 posts
Posted 16 October 2015 - 06:41 AM
See what I just highlighted in your previous post.  Now you're saying you don't see that?  Or am I confused?
#35 claps1775
claps1775
  • 596 posts
Posted 16 October 2015 - 06:44 AM
Maybe I am confused. Your talking about the qhload on the PC side? I am sorry. Been reading a lot up on it.
#36 SamuriHL
  • 44,375 posts
Posted 16 October 2015 - 07:06 AM
Yes.  If it shows that, you're hard bricked.  There's currently no coming back from that.
#37 claps1775
claps1775
  • 596 posts
Posted 16 October 2015 - 08:21 PM
Why I hate kit kat.
#38 claps1775
claps1775
  • 596 posts
I might try the Motorola forum. There has to be a way to fix it.
#39 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 17 October 2015 - 02:49 AM
There is. You buy a new main board.
#40 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 17 October 2015 - 06:44 AM
You're going to get more info here. I guarantee Sam and Painter are very knowledgeable.
There has been a fix for the Moto X because the files exist. Some people tried to worked on a fix for the Razr, but they were unsuccessful because the files don't exist.
Sent from my XT1575 using Tapatalk
