So my phone says home screen stopped responding or something similar to that. I am able to get the phone charged and up booted up to the Motorola "M" spashscreen but I cant go ay further and I can not use rsd to flash any img files and fast bood stays on "waiting for Device"
Posted 09 May 2015 - 06:22 PM
Posted 09 May 2015 - 06:55 PM
House of Moto can bring you out of this.
Read all instructions then read them again. When you read through the posts you will see others that have had the problem and fixed it.
- RikRong likes this
Posted 10 May 2015 - 04:27 PM
Alright I will try this, have been looking for weeks now and have had no luck, thanks ill will give this a shot hopefully it works
Posted 12 May 2015 - 05:59 PM
no luck with HouseOfMoto it keeps saying "failed to flash partition"
Posted 12 May 2015 - 06:50 PM
What file was you trying to flash. Also House of moto will create a log file read in the instructions how to grab it and cut and paste it to a post here so we can see what is going on.
Posted 13 May 2015 - 02:39 AM
Basically, you need to figure out what firmware your phone originally was on. You can't keep flashing random stuff and hope it will work.
Posted 13 May 2015 - 05:07 PM
I did get your PM, but I'd rather answer in a public forum so other people can see the answer.
i don't remember what firmware i was on as i updated unofficially through one of SamuriHL's utility's because i was rooted and not able to accept the ota update
Posted 13 May 2015 - 05:16 PM
would you wanna see the log from when i ran the HouseOfMoto.jar?
Posted 13 May 2015 - 05:23 PM
yes
Posted 13 May 2015 - 05:25 PM
yes
Posted 13 May 2015 - 05:41 PM
Ok everything looks like it is good there. First you said you couldn't get rsdlite to find the drive. That would either be usb, moto driver, or cable. Make sure the usb port is a 2.0 not 3.0 and the cable is a motorola cable reload the drivers.
unzip this to a folder on your hard drive. put your phone in fastboot mode and connect the cable. Go to the folder you unziped the snapdragon support file and open a command window. Switch to the windows folder and type fastboot devices and hit enter. This should bring a response back listing your devices serial number under devices. That will tell us if fastboot is working properly as well as the drivers.#12
Posted 13 May 2015 - 05:50 PM
If it does show your devices serial number type in fastboot getvar all cut and past that to a post here that will tell us what version your phone is running and also give a look for errors.
Posted 13 May 2015 - 05:52 PM
it should look something like this
moto_fastboot\Windows>fastboot getvar all
(bootloader) version-bootloader: 30B7
(bootloader) version: 0.5
(bootloader) cpu: MSM8960 Pro CS
(bootloader) ram: 2048MB Samsung S4 SDRAM DIE=4Gb
(bootloader) emmc: 32GB Sandisk REV=06 PRV=07 TYPE=17
(bootloader) product: ghost
(bootloader) revision-hardware: 0x8300
(bootloader) radio: 0x2
(bootloader) secure: yes
(bootloader) mid: 026b
Posted 13 May 2015 - 05:57 PM
is what i posted correct or did i do something wrong?
Posted 13 May 2015 - 05:58 PM
everything looks to be working ok there too.
you did everything right.
Posted 13 May 2015 - 06:01 PM
while it is still in that state go ahead and try to use house of moto again and run the flashme.bat file with out unhooking the phone.
Posted 13 May 2015 - 06:06 PM
no luck
Posted 13 May 2015 - 06:13 PM
what happend when you ran the flashme.bat file?
Posted 13 May 2015 - 06:16 PM
