How to unlock ext sdcard 4.4.2.
1 reply to this topic
#1 Scirca_xD
Scirca_xD
  • 75 posts
  • Google+:finnintaylor1214@gmail.com
  • LocationLe Roy NY
  • Current Device(s):Verizon LG Revolution 4GLTE, Motorola Droid RAZR M
Posted 25 April 2015 - 04:20 PM
Launch your favorite file manager with root access rights. You can use any app you prefer which can run elevated on your device. For example, the 'Root Explorer' app or 'File Manager' from CyanogenMod will do.Navigate to the following file:/system/etc/permissions/platform.xml
Find android.permission.WRITE_EXTERNAL_STORAGE and
android.permission.WRITE_MEDIA_STORAGE lines.
These are XML sections. You need to make them look exactly like the strings below
Save the platform.xml file. It’s necessary to set the file permissions to 644 (rw-/r–/r–) before mobile restarting. Now reboot your Android device. You are done.
Unfortunately, there is no known solution to me which could be suitable for non-rooted devices.
#2 parattodos
parattodos
  • 15 posts
  • LocationSalvador
  • Current Device(s):Motorola Droid Razr M xt907/Motorola G XT1032/Samsung Jack i637
Posted 04 May 2015 - 05:08 PM
I don't understand...
What is the bebefit of this modify?
