Poor cell phone reception with all roms
3 replies to this topic
#1 dvp95
dvp95
Posted 24 April 2015 - 05:22 PM
I have a razr maxx hd and I have tried all different roms I can find on Kitkat and Lollipop.  Every function works on the phones but the cell reception is terrible.  It is at least 2 bars less than stock roms and in  many areas in my apartment I have no reception at all.
Does anyone else have this problem?  Is there anything that can be done about it?  I want to use these other roms but the bad reception prevents me from using it because I cannot be without reception at all due to work.
#2 jl90
jl90
    \m/
  • 1,642 posts
  • LocationPhoenix, Az.
Posted 24 April 2015 - 08:19 PM
Tbh your cell reception is probably just as good as on stock even though it appears to be weaker. The signal bars do not give a very accurate representation of the signal strength. However, if you're experiencing dropped calls or text messages not being sent then I'd say stick with stock. I haven't had a stock OS on my phone since I upgraded to kit kat and haven't had signal issues since I built lollipop for the first time right after it became available.
  • RikRong likes this
#3 dvp95
dvp95
Posted 25 April 2015 - 09:40 AM
I think it is effecting me.  When it is down to 0 bars I have tried calling and texting it and there is no response.  Maybe when I move in a few months I will try it again.
Is this a common problem?
#4 jl90
jl90
    \m/
  • 1,642 posts
Posted 25 April 2015 - 02:58 PM
Not that I am aware of...Like I said, I personally haven't had any reception issues but that doesn't mean it can't happen. Maybe waiting and trying again is the best course of action in your case. :D
