XT926 stuck in AP Fastbbot
2 replies to this topic
#1 guapo613
guapo613
Posted 23 April 2015 - 08:22 PM
Here is what my phone says:
Device is LOCKED, Status Code: 0
Battery OK
Connect USB
Data Cable
Load Kernel (boot) failed
Fastboot Reason: Boot Failure
I have tried RSD Lite and House of Moto and both fail to work. RSD gives me the "Failed flashing process. "gpt.bin"
#2 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 24 April 2015 - 06:16 AM
Gotta know what version you were on before the failure, what you were doing when the failure happened, and what you attempted to flash.
sig by jayrod
The Rules-Follow them.
#3 guapo613
guapo613
Posted 24 April 2015 - 07:28 AM
Phone is completely stock 4.4.2 XT926 (KDA.62-20.15 I'm assuming). The phone just went into AP Fastboot one day for no apparent reason.
I'm assuming that the Boot Loader was corrupt but any attempt to wipe cache via recovery does not help, neither does factory reset.
I then used RSD Lite to try flashing the KDA.62-20.15.1 (183.46.15.XT926) but it fails as does House of Moto. Even if the phone was on 182.46.15, RSD Lite should be able to update it to 183.46.15 (I have done this on my other XT926).
Will installing and using ADB Fastboot on my PC help?, I found this link:
, what do you think?
