[ROM] [4.1.2] Aviator Blur - v3.0.9 [11/15/13] Pick Your Own Color!
Aviator ROM OTA ZKK007 Blur
2233 replies to this topic
#1 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 12 January 2013 - 02:40 PM
POPULAR
(BLUR Current Version 3.0.9)
Hi all,
Fly higher with Aviator! Please do not post this anywhere else without prior permission.
Other Aviator Versions:
Click on icon to got to that Aviator Version OP.
I am not responsible for anything that may happen to your device. (... nothing should happen)
NOTE: Some of the screenshots show the optional "White" color theme. You'll notice it in the status bar of the screenshots.
Click to
  • Deodexed.
  • Debloated.
  • Zipaligned.
  • Init.d tweaks - Battery and Performance based.
  • ADBD.
  • WiFi hack baked in (Use stock hotspot)
  • Pulldown toggles.
  • 1% battery.
  • Reboot in power menu.
  • Bootloader in power menu.
  • 4.2.2 Keyboard.
  • Volume rocker change music track mod.
  • Animation on notification pull down (hold the bottom bar on pull down) - Pictures removed, but code remains.
  • 10 in-call volume steps.
  • ES File Explorer (Can be uninstalled, not a system app).
  • Titanium Backup (Can be uninstalled, not a system app).
  • Battery Calibration (Can be uninstalled, not a system app).
  • No Frills CPU Control (Baked into settings. I.E. go into settings).
  • CPU Sleeper (Baked into settings. I.E. go into settings).
  • OTA Updater (Baked into settings. I.E. go into settings).
  • Beats Audio (Baked into settings. I.E. go into settings).
  • LED Control (Light Flow Lite) (Baked into settings. I.E. go into settings).
  • Chronus cLock widget (Baked into settings. I.E. go into settings).
  • SuperSU.
  • Apollo Music Player.
  • GPS tweaks.
  • Build.prop tweaks.
  • Aviator Utility (See post 2)
  • Custom theme – Wallpaper, boot animation, 3G/4G icons, and semi-transparency.
STS-Dev-Team - For all that they do/have done.
lownslow200sx – 98.72.8 Deodexed base and general help.
mhous33 - 98.72.16 Deodexed base.
Nitroglycerine33 – OG pull down toggles from ICS.
prstorero – Help with pull down toggles and reboot menu.
mattlgroff – Init.d and ADBD installation.
24v – Pull down animation and general help.
Bytecode – General Help.
Halo13 – Pull down toggle help.
East2West – Port over of volume rocker to JB and overclocking modules.
Dtrial, artur0588, and HSD-Pilot - GSM Patch information.
Travp - inverted calender.
jl90 - Safestrap 3.60 installation help.
If I have forgotten anyone, PLEASE PM me.
  • Transfer ROM zip file to SD card.
  • Reboot into SafeStrap (3.07, 3.11 or 3.6x)
  • Activate a different ROM slot or Stock slot.
  • Delete the ROM slot you want to use.
  • Recreate the ROM slot with desired slot size.
  • Install Aviator ROM file.
  • Reboot after installation.
  • Setup phone.
  • Go into Settings>CPU Sleeper. Check "Enable auto-start on reboot" (First Line), then "Start Service"(Second Line) (Press twice).
  • Let phone settle for 5-10 minutes then reboot for best results.
  • Charge to 100% for battery calibration or use battery calibration app from Play Store.
  • Enjoy!
ZKK007's Public Folder:
Aviator Blur 3.0.9:
(If you are updating Safestrap from 3.11 to 3.6x, you MUST delete the Safestrap folder on your internal SD before you reboot into Safestrap 3.6x for the first time. If you do not manually delete the folder, when you reboot you will get no data and text messaging will force close.)
PICK YOUR OWN COLOR THEME!
These are basic color themes which changes only the framework. Do not use the computer utility to remove toggles or install the simple battery. You can still use the overclock function of the utility.
Example of the Yellow Theme:
Click to
INSTALLATION:
  • Flash directly on top of ROM
DOWNLOADS:
OLD AVIATOR BUILDS:
Aviator Blur v3.0.8:
Aviator Blur v3.0.7:
Aviator Blur 3.0.7 Safestrap 3.11:
Aviator Blur v3.0.6 for Safestrap 3.11 and 3.60:
(Any version below v3.0.6 requires Safestrap 3.11).
Aviator Blur v3.0.5:
(AOSP Lockscreen, small stability issues)
Aviator Blur v3.0.4:
Aviator Blur v3.0.3:
98.72.16 BUILD "F22 Edition":
98.72.8 BUILD "F18 Edition:"
WALLPAPERS:
Download Wallpaper for "F22 Edition":
Download Wallpaper for "F18 Edition":
GSM PATCHES:
GSM Patch for v3.0.5-v3.0.7:
GSM Patch for v3.0.3, v3.0.4:
GSM Patch for "F22 Edition":
(Updated 04/10/13)
GSM Patch for "F18 Edition":
LOOK AT POST 3 FOR EXTRAS!
Click to
Want to show your Aviator Support with a custom Aviator signature image?
Instructions:
Edit your profile and go to signature.
Copy and paste this text:
Save and enjoy! :)
Kanging Policy:
Please feel free to use anything here for your personal, or public use. If you do use something from this thread, all I ask to to be given credit where it is due. You do not need to ask for written permission unless it is otherwise stated as part of a forum's kanging policy.
Don't forget to"Like" -->
Or if you want to Donate, click on signature image :)
  • Mr_Alexander, OldBaldy, cvhovey and 76 others like this
Donate? Click on signature :)
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 12 January 2013 - 02:41 PM
(Computer Only)
Using this utility you can remove or reinstall the quicksetting toggles, change the battery icon to a simple % icon, install the stock or inverted calendar, or overclocking!
Click to
FOR OVERCLOCKING: you will NEED SManager (free) and setCPU (PAID) ALSO You will need to install the modules using the utility. (Option 1 under overclocking menu).
Also, make sure your /system is R/W. Go into ES File explorer>settings>Root Explorer>Mount R/W and make sure all option are R/W.
USB Drivers:
Download for v3.0.9+
Download for v3.0.5-3.0.7:
  • Unzip file.
  • Run Aviator Utility.bat
  • Follow onscreen instructions.
  • NOTE: If you get a blank screen on boot, reboot.
  • Enjoy!
Aviator Utility
Click to
Aviator ROM
Click to
  • DTrainMusikVein, weaponx, mhotovec and 10 others like this
#3 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
4.1 Keyboard:
Download and flash in SafeStrap:
THEMES:
If anyone wants to make a theme for this ROM, go for it! No need to ask for permission. :)
Pink Floyd:
Download Page:
Red Baron:
Download Page:
Flying Sunset:
Download Page:
Aviator Boot Logo: BLUR and AOKP.
Anyone want an Aviator splash screen?
Download this:
and follow the instructions here:
Splash image example:
Safestrap Splash Screen: BLUR and AOKP.
Instructions:
  • Save the above images as "background-safe.png" and "background-nonsafe.png". Make sure they are 540x960..
  • Save to ext SD card.
  • Reboot into Stock ROM.
  • Use a root explorer (ES File Explorer, etc) and navigate to the pictures. MAKE SURE YOU HAVE R/W PERMISSIONS (Menu>root explorer>mount R/W).
  • Press and hold on the pictures, and copy the pictures.
  • Navigate to /system/etc/safestrap/res.
  • Paste and overwrite the existing files (Make a copy of the originals if you wish).
  • Reboot and profit!
Custom Aviator Widgets: BLUR and AOKP.
These were made in UCCW. Please download UCCW from the play store in order to use these files:
Instructions:
  • Download:
  • Unzip to get 2 .uzip files (weather and stat widgets)
  • Move .uzip files to /sdcard/UltimateCustonClockWidget/
  • Create widget by long pressing on screen, select Widgets, then UCCW. Choose 2x2 size.
  • Press menu, "Open uzip"
  • Navigate to /sdcard/UltimateCustonClockWidget/ and select the appropriate .uzip
  • Enjoy!
  • neckchop, canezila, dunttt and 6 others like this
#4 TeamFuzion
TeamFuzion
    Fuzion
  • 269 posts
  • LocationAll over the US :)
  • Current Device(s):RAZR, RAZR HD
Posted 12 January 2013 - 02:44 PM
Nice to see you got a ROM out :)
#5 Zack
Zack
    Developer
  • 94 posts
  • LocationArkansas
  • Current Device(s):OG Razr
Posted 12 January 2013 - 02:48 PM
Second. Never been second. Lol. Thanks for more crack
Why do I love jacking with my phone so much??
#6 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 12 January 2013 - 02:51 PM
Thanks! It was more for the learning experience but I'm glad I could share it with everyone!
  • johnthehillbilly and trekkin1707 like this
#7 luke61456789
luke61456789
  • 165 posts
Good stable ROM!
  • neckchop likes this
#8 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 12 January 2013 - 02:55 PM
Good stable ROM!
Thanks for being a tester!
  • neckchop and luke61456789 like this
#9 fishaholic
fishaholic
  • 157 posts
  • LocationSan Diego
I've been on this for a few days and it runs smooth, good battery and speed! :)
#10 luke61456789
luke61456789
  • 165 posts
Posted 12 January 2013 - 03:11 PM
you bet! I've gotten great battery life with your scripts as well
#11 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 12 January 2013 - 03:20 PM
Looks good bro! 24v told me you had this coming
#12 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 12 January 2013 - 03:24 PM
Looks good son glad to have more devs..... hope it all works out for you
#13 rickw
rickw
    corvette dude
  • 1,951 posts
  • Google+:rickwebb001@gmail.com
  • LocationDelaware
  • Current Device(s):S4 dev edition,moto x dev,Nexus 6
Posted 12 January 2013 - 03:42 PM
congrats,looks good
#14 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 12 January 2013 - 04:27 PM
This ROM is stable, quick, smooth, and amazing on battery. It gets even better with a day or two to settle in. On top of that, I think it's probably got the coolest boot animation ever. Haha. Thanks for letting me test, and thanks for developing. I look forward to seeing more. :-)
#15 TweakedSystems
TweakedSystems
  • 122 posts
Posted 12 January 2013 - 06:20 PM
I go to open safestrap > (unfortuantly safestrap has stop)
#16 jbartolovich
jbartolovich
  • 149 posts
  • LocationCleveland Area
  • Current Device(s):Nexus 4
Posted 12 January 2013 - 06:48 PM
Have it flashed. The custom wallpaper isn't loading though.
#17 theunbound1
theunbound1
  • 32 posts
Posted 12 January 2013 - 07:48 PM
i saw this on a friends phone the other day before I flashed JB on it. Seems as if the superuser binaries disappeared. This guy liked to pack his phone with malware though. Didn't matter since i wiped the phone clean for JB anyway.
#18 fishaholic
fishaholic
  • 157 posts
  • LocationSan Diego
Posted 12 January 2013 - 09:25 PM
Found a small issue
Google now won't update... says not signed correctly. I was able to uninstall and swap with a copy from the ota file..
Not a biggie but the only issue I have found in a few days lol :)
#19 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
  • Twitter:@usmcamgrimm
  • LocationMassillon, OH
  • Current Device(s):VZW G3
Posted 13 January 2013 - 03:13 AM
Looks good! Nice job!
#20 jpmoo
jpmoo
  • 145 posts
Posted 13 January 2013 - 03:43 AM
To fix Google Now, this usually works on the other ROM's.
Uninstall or delete Google Search in an app like TiBu or a file manager, reboot to recovery, wipe cache and Dalvic, reboot, install from Play Store.
Also tagged with one or more of these keywords: Aviator, ROM, OTA, ZKK007, Blur
