Stuck in Fastboot under linux/ubuntu
3 replies to this topic
#1 padalo
padalo
  • Current Device(s):Razr i
Posted 11 January 2013 - 02:30 PM
First of all hi everybody, and thanks to Matt for all his tutorials !
Former owner of a htc wildfire with cyanogenmod on, I decided to afford a more recent and funny phone, that is the razr. But since I am used to switch from Rom to Rom, I wanted to unlock the bootloader and to root it.
Therefore I followed Matt tutoriol over there on xda : http://forum.xda-dev....php?p=32576654 and I don't know exactly why, but i never got any answer from the phone during the script. I always stayed at :
user@computer:~/tmp/RAZRi_Root_Linux/files$ ./fastboot-linux-i386 oem get_unlock_data
< waiting for device >
Without having any answer. On this, I decided to launch the unrooting procedure, having put on the Usb debugging, and I quickly ended up with a failed flashing, and a phone that refuses to boot on any item of the menu (normal/recovery/factory/bp tools), be the usb cable active or not.
Now, I imagine that, since the flashing failed, I should flash another ROM, but my bootloader is not yet unlocked. Matt, everybody, any help on how to unlock it, knowing that I am using the latest version of Ubuntu ?
Another precision . I was using the latest vodafone.fr ROM, and there is the detail of my tentative of unlock :
user@computer:~/tmp/RAZRi_Root_Linux$ bash Root.sh
Resetting ADB and Launching Huawei MyTouch4G Root utility...
   This Isn't A Windoze Tool. Thanks obeygiant and stealthmouse!
[1] Root RAZR i
press any key to exit
Make your choice
1
Because its the utility Gotham deserves, but not the one it needs right now.
So, well hunt it, because it can take it. Because its not our hero.
Its a silent guardian. A watchful protector. A Dark Knight.
							 BATMAN BATMAN BATMAN
					N BATM N BATM N  ATMAN  ATMAN BAT AN BAT
				ATMAN	 AN BATMAN		 ATMAN BAT	  TMAN
			AN B		 MAN BATMAN		 ATMAN BATM		  BATM
		  TMA			MAN BATMA		   TMAN BATM			 MAN
		BAT			   AN BATM			 MAN BAT			   AN B
	  N BA	  ***********************************************	 BA
	  N B	   *			Motorola RAZR i Root			 *	  BAT
	 AN B	   *		   Created by mattlgroff			 *	  BAT
	  N B	   *	   batakang.com  ||  DroidRzr.com		*	 BA
	  N BA	  ***********************************************	 N BA
		BAT		AN BAT	 ATMAN		  TMAN	MAN BATM	  MAN
		 ATMA	  AN BATMA  BATMAN B	  BATMAN B TMAN BAT	  TMA
		   MAN B	N BATMAN BATMAN BA   N BATMAN BATMAN BA   N BAT
			 BATMA  BATMAN BATMAN BAT AN BATMAN BATMAN  ATMAN
				 AN BATMAN BATMAN BAT AN BATMAN BATMAN BA
						  N BATMAN BATMAN BATMAN B
Plug the phone in with a USB cord and have it booted up normally.
Go to Settings .Developer Options and enable USB Debugging.
If these are done press any key to continue.
sending 'boot' (11264 KB)...
OKAY [  1.195s]
writing 'boot'...
FAILED (remote: Preflash validation failed)
finished. total time: 1.565s
rebooting...
finished. total time: 0.308s
Phone is rebooting please dont touch anything.
I never had any news for 10 minutes after this last line, and I disconnected the usb cable.
  • yondaime_fenix likes this
#2 padalo
padalo
Posted 11 January 2013 - 03:11 PM
I finally understood why the device was not found : I needed to «sudo» in order to give to the fastboot utility access to usb ports apparently.
#3 padalo
padalo
Posted 11 January 2013 - 03:32 PM
So, I think I solved it myself : after using the fastboot version that allows to flash more than 100 MB and unlocking the device, I could reflash another boot image, and it worked :)
#4 yondaime_fenix
yondaime_fenix
  • 6 posts
Posted 23 February 2013 - 09:02 AM
it's nice that you have solved this problem, it could help someone else having the same problem =D
Enviado desde mi XT890
