Went swimming...
4 replies to this topic
#1 kfa670
kfa670
  • 6 posts
  • Current Device(s):Droid RzR Maxx
Posted 10 April 2015 - 03:07 PM
With my 926 in my pocket.  OOps.  I pulled the phone out and it was soaked with the red LED on.  I took it home and took it apart, dried everything out really well and looked for any noticeable damaged components.  Didn't see anything so I put it back together and it booted up.  I then decided that I thought I would just turn it back off and let it air out on its own for the rest of the night.
Now she doesn't even turn on anymore.  If I plug it into the charger the best I get is a constant green LED that turns off the minute I pull the plug.
I'm just curious if anyone has any suggestions.  Maybe battery is shot?  Or should I just get a damn new one...
#2 johnthehillbilly
Posted 10 April 2015 - 03:10 PM
I would say it's toasted..... :(
#3 kfa670
kfa670
  • 6 posts
Posted 10 April 2015 - 03:36 PM
Kinda what I'm thinking :p
#4 LDubs
LDubs
    Pawn In Game of Life
  • 9,691 posts
  • Twitter:lew_bklyn
  • LocationBrooklyn, NY
Posted 17 April 2015 - 11:54 AM
water and tiny electrical components do not play well together.  Something got shorted out.  Time for a new one.
  • johnthehillbilly likes this
#5 johnthehillbilly
Posted 17 April 2015 - 01:55 PM
Some parts MAY not be damaged (headphone jack, USB port, HDMI port, sim slot, etc) if you're adept with solder/de-solder you can remove those parts ... And keep them for spares
