Flash Error. Bootloader variable not supported ...
7 replies to this topic
#1 Scirca_xD
Scirca_xD
  • 75 posts
  • Google+:finnintaylor1214@gmail.com
  • LocationLe Roy NY
  • Current Device(s):Verizon LG Revolution 4GLTE, Motorola Droid RAZR M
Posted 10 April 2015 - 09:22 AM
I've successfully installed adb and fastboot on my Windows PC.. And I have the correct drivers installed for both my phone and my fastboot. And I am trying to flash a recovery image to my phone. TWRP to be specific. I am not rooted. When running adb everything seems fine I can reboot to bootloader and it recognizes my device as a list of fastboot devices when in fastboot. So my issues appears to be when I type the following code
Fastboot flash recovery twrp.IMG
And it says bootloader variable not supported.. And I can't seem to get twrp on my phone I'm a little confused.. Any suggestions ?
#2 johnthehillbilly
Posted 10 April 2015 - 09:31 AM
Wrong fastboot (fastboot.exe)
Or you have multiple fastboot in your [system] PATH and its trying to use the wrong one
#3 Scirca_xD
Scirca_xD
  • 75 posts
  • LocationLe Roy NY
Posted 10 April 2015 - 09:33 AM
Path as in my SDK tools where I run my cmd from or the system path of my pc
#4 johnthehillbilly
Posted 10 April 2015 - 09:49 AM
If you're running cmd from within the SDK folder.... Then chances are you need another fastboot.exe .. (Grab the one from Sam's, House of Moto, and copy it ) :)
If you have not manually edited your computer system PATH then you need not worry about it pointing to the wrong fastboot
  • Scirca_xD likes this
#5 Scirca_xD
Scirca_xD
  • 75 posts
  • LocationLe Roy NY
Posted 10 April 2015 - 10:22 AM
Okay I'll give it a test.
#6 Slideways
Slideways
  • Current Device(s):Razr M
Posted 30 June 2015 - 02:40 PM
Any update on this?
I have the same situation, tried flashify fastboot almost everything. xt907 updated to 4.4.2 rooted and BL unlocked but I cant flash recovery. I have used many fastboot's even mfastboot v2 all in their own repective folder. currently DL'ing the most uptodate SDK to try and solve this. No point in having an unlocked bootloader if I cant flash a new rom through recovery haha. when I let flashify load the recovery it says it works fine, but when I hold IO Vol+ ans Vol- then choose recovery it stays at the inlocked bootloader warning for about 2 min then resets to unlocked BL screen then powers on like normal.
#7 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 30 June 2015 - 02:51 PM
Any update on this?
what recovery are you trying to flash?
Here is a link for TWRP from dhacker29.
Use the download now option so it doesn't use the download manager.
#8 Slideways
Slideways
Posted 30 June 2015 - 04:07 PM
Well I was trying to flash any that would technically work with xt907 KK I even tried an older version of the one you posted and now with fastboot from 01/07/2015 it finally flashed and now It is working. I spent all last night browsing forums and nothing worked untill now I tried every version of cwm i could and none would flash but now I am good to go.
Thank you so much. The main problem I was having other than the flash not taking was that there are so many dead links out there.
Thanks again.
Slide
