Best Answer livinginkaos , 12 April 2015 - 04:55 AM
There should be no need to erase user data
sent from my N6
Go to the full post
sent from my N6
Go to the full post
Posted 10 April 2015 - 07:23 AM
Phone is a Motorola Droid Razr Maxx HD
xt926 stuck in ap flashboot mode.
I know the attached photo is not readable so I entered it:
AP Flasboot Flash Mode (S)
10.9B(*) (sha-61146a2, 2014-05-02 03:15:48)
eMMC Info: Size 32GB
Battery OK
Transfer Mode:
USB Connected
No valid PIV block in SP for system
PIV validation failed (system)
Fastboot Reason: Boot Failure
Going into recovery with (Vol + and Pwr) works.
However, the phone immediately flashes the red Motorola logo then right back into flashboot mode.
The phone is stuck in fastboot mode.
I've tried to reinstall stock rom via RSD Lite. Will not work. Starts, then fails within a second.
Any ideas on how to solve this?
9
80
Posted 11 April 2015 - 10:04 PM
here is the fix
Posted 12 April 2015 - 04:55 AM Best Answer
Posted 23 April 2015 - 07:44 PM
here is the fix
1. adb reboot bootloader2.fastboot oem fb_mode_set3.fastboot oem fb_mode_clear3.fastboot erase userdata4.fastboot erase cache5.fastboot reboot
Where do I enter these commands?
Posted 10 May 2015 - 09:45 PM
you need to connect your phone to the computer
then open dos window then add the commands
Posted 20 February 2016 - 06:53 AM
here is the fix
This helped me in a major way, thanks for the info!
