[Gsm] Full Zip To Flash Ics Leak From Cwm
Posted 01 February 2012 - 12:35 PM
Tested it myself. I was on 6.5.1-73_SPU-11-M1-2 before, and I booted fine into ICS.
Flash using CWM Bootstrap Recovery (XT910 / umts only!)
MD5: a395d62c7cb321d9b057a209b750b7f6
Link:
It works on: EU Retail.
It does NOT work on: Retail BR / Latam RAZR.
- B_ren likes this
Posted 01 February 2012 - 01:46 PM
Posted 01 February 2012 - 02:20 PM
Posted 01 February 2012 - 02:22 PM
- mattlgroff and adlx like this
Posted 01 February 2012 - 02:26 PM
any word on this matt??? just curious what happened when u did... (obviously i know the answer to my question) but wanted to ask
Matt is RSDing right now lol... just kidding idk
Posted 01 February 2012 - 02:33 PM
Gonna be dumb and flash it to CDMA Razr, I'll let you know how it goes haha
It shouldn't work on a CDMA. It will flash the boot.img and I guess it will fail to boot. I believe GSM and CDMA use diferent keys to sign the partitions.
So, please people don't try that, unless you are as experiences as Matt!
Posted 01 February 2012 - 02:42 PM
But no Wifi :S
Posted 01 February 2012 - 03:02 PM
Failed as expected.It shouldn't work on a CDMA. It will flash the boot.img and I guess it will fail to boot. I believe GSM and CDMA use diferent keys to sign the partitions.
Posted 01 February 2012 - 03:22 PM
works great on GSM !! thanks you very much adlx !
But no Wifi :S
Wifi is working on mine.
Posted 02 February 2012 - 04:41 AM
Posted 02 February 2012 - 05:34 AM
- adlx likes this
Posted 02 February 2012 - 05:42 AM
Posted 02 February 2012 - 05:51 AM
Why the camera display so dimmer than before. and my phone always hung+freeze after using yhis ICS
It's is (should be) the very same "stock ICS" as leaked by Motorola, I haven't modded it. The only modification made is root (su/Superuser) & busybox installed.
Unfortunately it's buggy, sometimes laggy, a lot of freeze, soft-reboots and such. It's not intended to be a daily rom .
Now you can use that to flash it easily (more easy than fastboot + applying two full OTAs)
Posted 07 February 2012 - 03:32 AM
hi i also have installed ICS and find it to buggy i want to go back to 2.3.6 how exactly do i do it i dont want to brick my phone, i copied the ICS update to my memory card then did system restore update from SDcard to update ICS am i able to just put 2.3.6 on sdcard and update to that or do i have to do something elseA lot of bugs !! freeze etc ! not smooth. I return on 2.3.6 for the moment.
Posted 07 February 2012 - 02:06 PM
You can find out how to do that in the how to sections in the forum
Posted 08 February 2012 - 01:45 AM
#You can find out how to do that in the how to sections in the forum
There is NO how to section under GSM only CDMA and thats the american phone
Posted 08 February 2012 - 01:49 AM
Posted 08 February 2012 - 02:39 PM
To begin, thanks a lot for this zip, it's way faster than through all OTAs!
I noticed that the rotation of the screen doesn't work. I went into the display settings and "auto rotate" is ticked.
Has anyone experienced this?
Thanks for your feedback!
Posted 09 February 2012 - 08:12 AM
Hello everyone!
iirc it doesn't work in motorola launcher , but in apps it is working
- Trombazzucche likes this
