I did something stupid and wanted know there is a easy solution to issue. I updated my Moto XT912 rooted with kitkat while on stock JB 4.1 to 4.1.2(98.72.165XT912). I wanted to know how do I rooted and get my KITKAT back. I found the safestrap is still on the phone and rom is still saved but just dont know how to access and run it. Can you HELP!!! Thank you!!!!!!!!!!!!!
Updated Stock rom
Posted 05 April 2015 - 05:11 PM
Posted 05 April 2015 - 05:52 PM
Posted 05 April 2015 - 07:39 PM
Sent from my XT1060DE
- Johnny5droids likes this
Posted 06 May 2015 - 04:11 PM
If I read you correctly, all you need to do is re-root with Moto saferoot, reinstall safestrap, enable recovery, and you'll be good to go. Your kk rom should still be there unless you erased your safestrap folder.
That is what i did. But couple of days later it began to crash randomly. Today I decided upgrade my SD card so I went to copy all my files for safestrap. Rebooted phone with new SD card didnt work. Than tried old one worked but google account asked me to verify my password. I tried but failed so i decided to reboot. Damn thing rebooted into stock and wiped my entire phone. I mean factory wiped, no media, no files, nothing everything gone. I dont know what I did but I lost everything in one reboot. Very frustrated and pissed.
