[Recovery] Droid Razr Bootstrap Recovery *updated 2/8/12
#161
Posted 12 May 2012 - 06:45 PM
my slot to External SD is empty.
"his is an unofficial bootstrap recovery for the Droid Razr. It is based off of Koush/CVPCS bootstrap for the Droid Bionic and modified for the Razr.
Flash zips at your own risk! Enjoy! Updated on 2/8/12 to fix backup and restore features as well as adding support for internal and external sd cards.
Download:
Steps to use bootstrap:
1. Install the RazrBootstrap.apk
2. Select "Bootstrap Recovery"
3. Superuser will prompt for permissions
4. Select "Reboot Recovery"
When the phone reboots it will boot up into Clockworkmod Recovery."
Font:
#162
Posted 12 May 2012 - 06:52 PM
"This is an unofficial bootstrap recovery for the Droid Razr. It is based off of Koush/CVPCS bootstrap for the Droid Bionic and modified for the Razr.
Download v2.0:
Font: Mr Eclipse; in this topic.....http://www.droidrzr.com/index.php/topic/66-recovery-droid-razr-bootstrap-recovery-updated-2812/
#163
Posted 12 May 2012 - 07:02 PM
Thanks for the links, and I am sure it will be handy very soon, BUT, the latest OTA update for the razr is the 812 (6.12.181.XT912.Verizon.en.USThere is an ICS specific bootstrap... lemme grab the link real quick...
[ my name is Jonas ]
This is the update that took away my "Recovery Option" BEFORE BOOT (Same as CWR before boot)
SO, I'm worried if that is ICS specific, then???
I was speaking to Verizon today, and they told me, they pretty much (This was a level 2 tech support), they can see the updates they got from Moto, and are about to be released, but beyond that, they don't know any dates or anything. Now I'm sure somewhere up the ladder at Verizon there is, but, as far as who you can call, all they can say is they have it and it will be out soon (They won't know till within a week or two). The guy I was talking too, also had the Razr, told me he paid the 300 for it same as me, thinking ICS was right around the corner, here we are now, the phone is down to 99 bucks and still no ICS.....LETS NOT EVEN TALK ABOUT THE PROMISED UNLOCKED BOOTLOADER......
SORRY TO GET OFF THE OP...Just venting.....
But, all I really wonder is what safe/boot strap will give me a BEFORE BOOT option for CWR??
THANKS....JEFF
#164
Posted 13 May 2012 - 09:44 AM
#165
Posted 13 May 2012 - 10:01 AM
Is it possible to flash the ICS leak of 4.0.3 coming from the latest OTA .181 using CWM recovery that is installed with Bootstrap v2.0?
No -- the ICS updates change the kernel and radio which can only be done from stock recovery
#166
Posted 14 May 2012 - 04:00 PM
#167
Posted 14 May 2012 - 04:02 PM
#168
Posted 15 May 2012 - 01:17 PM
Can someone help me with this? Thank you
#169
Posted 15 May 2012 - 03:48 PM
I think you are confused. There is no ICS 173 or 181. Those are Gingerbread builds. The Simplexrom is for those people stuck on the 6.14.84 ICS leak. That ROM wasn't meant for you to flash straight from Gingerbread. And you don't want to flash the .84 ics leak just to get that rom either. There is an ICS .75 leak you can install from Gingerbread.Help please? Second brick in 48 hours. Was on safestrap ics 173..Updated 181 but didnt protect root...lost root used droidrazr utlility back to stock 173...Install Razr Bootstrap...Boot into recovery....downloaded Simplexrom 175 because forum thread said ok, flashed in recovery..Stuck on m logo
Take a few minutes to read things carefully before you start flashing stuff.
#170
Posted 15 May 2012 - 03:51 PM
Maybe post in the GSM threads? This is for CDMA.I have a question. I have a gsm razr. I live in ottawa canada and when I rooted my phone I have safestrap installed. I just read that safestrap wont work on gsm phones only bootstrap will and I cant find a clear step by step to remove safestap and install bootstrap.
#171
Posted 22 May 2012 - 12:43 AM
can i do cwm on my razr maxx with the ics leak 4.0.3 ?
any info ty
#172 Guest_BDH_*
Posted 22 May 2012 - 12:59 AM
noob question
any info ty
If you're asking if you can install this Bootstrap over ICS, the answer is no. This Bootstrap is NOT compatible with ICS. However, there IS an ICS Bootstrap which can be found here:
#173
Posted 22 May 2012 - 01:23 AM
ty but link is broken for the downloadIf you're asking if you can install this Bootstrap over ICS, the answer is no. This Bootstrap is NOT compatible with ICS. However, there IS an ICS Bootstrap which can be found here:
#174
Posted 22 May 2012 - 07:10 AM
#175
Posted 08 August 2012 - 07:37 PM
#176
Posted 13 August 2012 - 11:05 AM
Is there any way to prevent this recovery from starting up when I reboot the phone?
#177
Posted 05 February 2013 - 10:08 AM
#178
Posted 31 May 2013 - 06:45 PM
Possible noob question: When I run the bootstrapper, I get into CWM, flash CM10.1 without any errors, then on reboot, I get encryption unsuccessful screen and have to re-flash my phone back to jellybean using the droid razr utility by mattlgroff. After some testing, I've narrowed this down to when I run the bootstrap recovery and then restart. Does anyone know what's going on?
#179
Posted 01 June 2013 - 05:13 PM
Sent from my SCH-I535 using Xparent Cyan Tapatalk 2
#180
Posted 01 June 2013 - 07:35 PM
Download v2.0:
When the phone reboots it will boot up into Clockworkmod Recovery. (THIS IS A FAKE LINK) FAKE DOWNLOAD LINK!!!!
