[Recovery] Droid Razr Bootstrap Recovery *updated 2/8/12
201 replies to this topic
#121 Badger50
Badger50
  • 241 posts
  • Google+:badger50@gmail.com
  • LocationKansas City
Posted 18 February 2012 - 01:00 PM
Just out of curioscity, do you think it matters which Zergrush root you use?? I rooted my Dx2 using Doomlords #4 version, and BSR worked flawlessly.. I have seen versions 2 and 3 talked about for rooting the Razr along with Voodoo's root keeper. I have used versions 3 and 4 to re-root the Razr after after FB back to .744, yet it does'nt seem to make a difference to the BSR recovery. Just curious, and thanks to all the wonderful, and helpful people in the android community :-)
#122 superstargoddess
superstargoddess
  • 126 posts
Posted 20 February 2012 - 07:49 AM
Loves me some Bootstrap.
Yeah, Doomlords v4 and the new version of the Android Utility by Matt is good now. Matt's didn't used to work, but it caught up and keeps root the whole time now.
- Motorola Droid RAZR [IC3Razr- always most recent]
#123 mgrimmenator
mgrimmenator
  • 103 posts
Posted 20 February 2012 - 04:32 PM
glad to see ya over here nitro. i just got this phone as upgrade from my fascinate. can't wait to see some of your work on here.
#124 Badger50
Badger50
  • 241 posts
Posted 21 February 2012 - 02:41 AM
Problem solved :-) For those of you still having the "Error while restoring system" while trying to restore a Rom. I used Mattlgof's utility (it's awesome:-) Did a FB back to .173, let the utility wipe your internal sd card. Then re-root using the new utility exploit. Install the BSR, and bingo. Now the restore function works smooth as butter. A big thank you to Matt and his awesome utility program, he's definitely getting some of my money :-)
  • killajz likes this
#125 stupidchicken03
stupidchicken03
  • 104 posts
  • LocationIn the Sac of CA
Posted 21 February 2012 - 08:06 AM
I might have to look into doing that now haha
#126 schmidtythekid
schmidtythekid
  • 12 posts
  • LocationBoise, ID
Posted 01 March 2012 - 03:13 PM
i installed the bootstrap but when i press reboot recovery it doesn't do anything.. i had done a factory reset cuz i was trying to install the other way so i had to redownload my super user and the bootstrap never asked for super user permissions. did i loose my root?
#127 Canemaxx
Canemaxx
  • LocationNEW HAMPSHIRE
Posted 02 March 2012 - 12:11 AM
will this recovery work to flash any rom?
#128 DSGMach1
DSGMach1
    Themer
  • 264 posts
  • LocationGriffin, GA
Posted 07 March 2012 - 01:21 PM
Just want to clarify. If I already have bootstrap can I just follow the install instructions and install it over the bootstrap already on the phone or do I need to uninstall first?
#129 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 08 March 2012 - 06:42 AM
Correct just install the new bootstrap over the old one.
#130 ddemlong
ddemlong
  • 137 posts
  • LocationPhoenix, AZ
Posted 08 March 2012 - 09:24 PM
I have done that several times through flashing and accidently boot looping and I still get the error every time i try to restore a system. Its irritating. :angry:
Droid RAZR Rooted
#131 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 20 March 2012 - 02:13 AM
does this work for GSM razr? Im on a GSM razr and when i press reboot recovery, it reboots and gets stuck at DualCore technology screen, please help D:
  • thomasthambi likes this
#132 Cigarrr
Cigarrr
Posted 24 March 2012 - 10:32 PM
This does not work on my unlocked device and gets stuck on first "M" logo.
Need help.
Thanks.
#133 Guest_BDH_*
Guest_BDH_*
Posted 02 April 2012 - 12:04 AM
This works on the CDMA ICS Leak as long as you kept root! Thanks nitro!
#134 nitroglycerine33
nitroglycerine33
    Mr. Eclipse
  • 224 posts
  • Twitter:nitroglycerin33
  • LocationIowa
Posted 02 April 2012 - 04:12 AM
Need help.
Thanks.
Why would you use this on an unlocked razr? You can flash a true recovery image.
Sent from my Galaxy Nexus using Tapatalk
Donations are not expected but always greatly appreciated. Thank you for supporting Eclipse Rom!
Follow me on Twitter @nitroglycerin33
#135 superstargoddess
superstargoddess
  • 126 posts
Posted 02 April 2012 - 08:16 PM
Unfortunately it won't restore the leak if you mess it up and have to go back to stock. =/
#136 nitroglycerine33
nitroglycerine33
    Mr. Eclipse
  • 224 posts
  • LocationIowa
Posted 03 April 2012 - 09:27 PM
I just got back to my razr. What do you mean it won't restore ICS? Or are you talking about restoring a gingerbread backup?
#137 Guest_BDH_*
Guest_BDH_*
Posted 04 April 2012 - 12:53 AM
I haven't tested it yet but it was said that this recovery won't restore a nandroid. GB or ICS Leak.
Sent from my Rooted Stock ICS Droid RAZR using tapatalk.
#138 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 04 April 2012 - 02:16 AM
I thought you had successfully restored a backup you made running the ics leak? Or are you referring to using a nandroid (ics leak) to install a fresh copy of the leak from 173?
#139 jfmi81
jfmi81
Posted 11 April 2012 - 11:47 AM
I could use some help. I downloaded the file moved it to my SD card and Unzipped it. In your tutorial you say Steps to use bootstrap:
1. Install the RazrBootstrap.apk. I would if there was a .apk in the unzipped folders. I do not see a .apk on my phone or pc when i unzip this download. Can anyone tell me whats going on?
#140 ssmaynv
ssmaynv
  • 243 posts
  • LocationLas Vegas
Posted 11 April 2012 - 01:55 PM
If you see a META directory after unzipping, you need to flash the zip.
