[Recovery] Droid Razr Bootstrap Recovery *updated 2/8/12
201 replies to this topic
#101 DonDraper
DonDraper
  • 156 posts
  • LocationLexington, SC
Posted 16 February 2012 - 07:26 PM
fastboot restore (as in with mattlgroff's utility) will erase every trace of this, correct?
#102 Baby Duck
Baby Duck
  • 61 posts
Posted 16 February 2012 - 08:29 PM
How come every time I try to flash one of my recovery it never works. It always says error restoring system.
#103 snives
snives
  • 947 posts
Posted 16 February 2012 - 08:36 PM
You aren't giving us anything to go on here... For a first guess since we don't know what process you used, the most common culprit is not clearing cache/dalvik before making the backup.
  • Baby Duck likes this
#104 weaponx
weaponx
  • 413 posts
  • LocationTX
Posted 16 February 2012 - 08:40 PM
I had no idea that was something you are supposed to do. You are saying that BEFORE we make a backup we need to clear cache and dalvik cache? Ok, after that, make your backup, and the restore should work? Can someone Verify?
Hey bub, I'm not finished with you yet..... SKNIT!!
#105 Baby Duck
Baby Duck
  • 61 posts
Posted 16 February 2012 - 08:49 PM
I didn't know that either. Thanks I'll try that. I'm using bootstrap 2.0
#106 snives
snives
  • 947 posts
Posted 16 February 2012 - 08:59 PM
Yes, it is always best to wipe cache/dalvik before creating a backup, and also before restoring. Both times the goal is to eliminate data that can potentially cause issues. Due to the data being volatile anyways, there is really no danger in doing it either. For that sake, it is good practice to wipe both any time you open a recovery, and every time before you leave it. I believe DT has commented on this before as well, but I don't remember when/what thread to point you to for confirmation.
Found it ;)
  • killajz likes this
#107 weaponx
weaponx
  • 413 posts
  • LocationTX
Posted 16 February 2012 - 09:04 PM
Thanks, Snives, this helps a lot
#108 Baby Duck
Baby Duck
  • 61 posts
Posted 16 February 2012 - 10:11 PM
I wiped cache partition then wiped cache/dalvik made a backup with Razrbootstrap v2.0 rebooted went back into bootstrap wiped same things again tried to restore my backup and the same thing happend, Error while restoring /system. I have never had successful restore. What am i doing wrong?
#109 nitroglycerine33
nitroglycerine33
    Mr. Eclipse
  • 224 posts
  • Twitter:nitroglycerin33
  • LocationIowa
Posted 17 February 2012 - 04:42 AM
Do you have rootkeeper installed?
Donations are not expected but always greatly appreciated. Thank you for supporting Eclipse Rom!
Follow me on Twitter @nitroglycerin33
#110 Baby Duck
Baby Duck
  • 61 posts
Posted 17 February 2012 - 08:40 AM
Yep. Does that make a difference?
#111 stupidchicken03
stupidchicken03
  • 104 posts
  • LocationIn the Sac of CA
Posted 17 February 2012 - 12:42 PM
I have it installed too
#112 nitroglycerine33
nitroglycerine33
    Mr. Eclipse
  • 224 posts
  • LocationIowa
Posted 17 February 2012 - 02:18 PM
I have not tested it on the razr but on the x2 it jacks up the system
#113 weaponx
weaponx
  • 413 posts
  • LocationTX
Posted 17 February 2012 - 02:32 PM
So uninstalling this root keeper app fixes the issue? ...so uninstall the app, clear cache and dalvik cache, make the backup, for restore, clear both caches, then restore...now it should work? Am I missing something?
#114 Badger50
Badger50
  • 241 posts
  • Google+:badger50@gmail.com
  • LocationKansas City
Posted 17 February 2012 - 08:16 PM
Went back to .744, updated, used root keeper for the initial root to .173, reinstalled BS 2.0, deleted all previous backups, made new ones and.......still the same problem :-( Oh well, at least advanced restore still works :-)
#115 stupidchicken03
stupidchicken03
  • 104 posts
Posted 17 February 2012 - 08:31 PM
Whats the diff with Restore and Advanced Restore?
#116 Badger50
Badger50
  • 241 posts
Posted 18 February 2012 - 09:53 AM
Advanced restore allows you to individually restore separate parts of your Rom..ie: system, data, boot, and cache. I have found that no particular order is required. I usually do cache, data, boot, and system last. I still get the "Error while restoring system" warning, however, my Rom always comes back just the way I left it. It takes longer, and it's a little bit of a hassle, but at least it works. Damn moto bootloader :-(
#117 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 18 February 2012 - 10:23 AM
I had this same issue when trying to restore a backup the first time I used Voodoo OTA Rootkeeper. Temp unroot first, then boot into bootstrap recovery & the backup should allow you to fully restore it! You can either restore root after, or reroot & re-protect root with Voodoo again.
#118 Badger50
Badger50
  • 241 posts
Posted 18 February 2012 - 11:10 AM
Wouldn't completely uninstalling voodoo accomplish the same thing?? I have tried to make BSR 2.0 work so many different ways....and all I can do is keep using advanced restore to get the job done. So I might as well give this one a go. Thanks man :-)
#119 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 18 February 2012 - 11:13 AM
Yes.
#120 Badger50
Badger50
  • 241 posts
Posted 18 February 2012 - 11:19 AM
Which I tried, but my unfortunately, I still get the same result :-( Thanks anyway :-)
