[Recovery] Droid Razr Bootstrap Recovery *updated 2/8/12
201 replies to this topic
#81 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 03 February 2012 - 06:50 PM
Is there a problem with this app not being able to restore /system?
My experience with this....
Safestrap would get errors restoring /system so I stopped using it.
Bootstrap worked great until I flashed 173 then I started getting /system restore errors again.
I did a fastboot on phone and upgraded to 748 and made a backup. Restored and /system restore worked great.
Upgraded to 173 and once again /system restores would fail.
I tried 3 more times and each time, 748 would restore fine and fail on 173.
Now I just do an advance restore and restore them manually. System still fails but it seems to still flash all of system.
#82 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 03 February 2012 - 06:54 PM
Yep...after trial and error, I found this out too. More steps but it does work. :)
#83 nitroglycerine33
nitroglycerine33
    Mr. Eclipse
  • 224 posts
  • Twitter:nitroglycerin33
  • LocationIowa
Posted 08 February 2012 - 10:10 AM
Updated with version 2.0. Fixed backup/restore errors and added internal and external sdcard support.
  • mattlgroff likes this
Donations are not expected but always greatly appreciated. Thank you for supporting Eclipse Rom!
Follow me on Twitter @nitroglycerin33
#84 AsosaYoung
AsosaYoung
  • 146 posts
  • Twitter:OGissimO
  • LocationLong Beach, Ca
Posted 08 February 2012 - 10:37 AM
So this does not install over the old 1. So we delete old 1 first.?
#85 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 08 February 2012 - 12:07 PM
Thanks nitro.
#86 cdfjr1975
cdfjr1975
  • 78 posts
  • LocationLas Vegas
Posted 08 February 2012 - 12:16 PM
Updated fine for me with no delete, not sure if it's the preferred way our not but no problems here
#87 stupidchicken03
stupidchicken03
  • 104 posts
  • LocationIn the Sac of CA
Posted 08 February 2012 - 04:14 PM
Ill be installing this for the first time, will i still follow the install instructions from the OP, but with the new 2.0 file inplace of the 1.0 file?
#88 tyrthas
tyrthas
    CassDroid's Personal Stalker
  • 455 posts
  • Twitter:@tyrthas
  • Google+:Ron Becker
  • LocationMissouri
Posted 08 February 2012 - 04:57 PM
Yep. Just download the apk and follow the instructions like normal. :)
Sent from my XT912
  • stupidchicken03 likes this
#89 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 08 February 2012 - 05:45 PM
Thanks again nitro!
#90 stupidchicken03
stupidchicken03
  • 104 posts
Posted 08 February 2012 - 09:25 PM
Installed and working great :)
Just finished my first back up
#91 stupidchicken03
stupidchicken03
  • 104 posts
Posted 09 February 2012 - 08:37 AM
Video of getting Bootstrap CWR on boot every time
http://www.youtube.com/watch?v=B65qdm7cd58
Have they made anymore progress with this? Say maybe a "timeout" option, to where if you dont select anything withing 8-10 seconds it would just boot normally? Ive got an HP TP running CM7, and thats how it boots every time.
#92 Badger50
Badger50
  • 241 posts
  • Google+:badger50@gmail.com
  • LocationKansas City
Posted 11 February 2012 - 05:41 PM
Still having the same problem as before. I even SBF'd back to .744, did all the updates, and installed the new 2.0 apk. I can still restore everything just fine using advanced restore, however the "Error while restoring system" is still occuring. Anyone else having the same issue??? Thanks again Nitro for all your hard work.
#93 stupidchicken03
stupidchicken03
  • 104 posts
Posted 11 February 2012 - 06:31 PM
I havnt tried a restore yet... currently in the process of making my 2nd backup.
My question tho is this:
The backup is installed on the SD card under the "clockworkrecovery" folder. Then a subfolder for "backup" then sub folder(s) with the individual backups that are named with the dates they were created.
SO, can you rename those folders (instead of leaving the date)?
I would like to name each backup as "X done", "X now done" ect ect (so i know the differences of what was added/removed for each backup). Would that affect the restore at all?
#94 Badger50
Badger50
  • 241 posts
Posted 11 February 2012 - 06:59 PM
You have to leave the date and time, or you will mess up the md5 sum. I learned this one the hard way. Leave the date and time alone, then add an underscore _ then the name you want to call it. Ie: 2012-02-11.04.53.55_Eclipse_Done
#95 stupidchicken03
stupidchicken03
  • 104 posts
Posted 14 February 2012 - 11:06 AM
I was in boot loop yesterday.
Did a factory reset, rerooted, installed BS and tried to apply my backup from restore. I got the "Error while restoring system" too :(
#96 NickL83
NickL83
  • 37 posts
  • LocationBranford, CT
Posted 15 February 2012 - 07:04 AM
hey guys question, if I want to switch over to safe strap, would I somehow how to uninstall the jy daddy .zp before installing safe strap? or just removig bootstrap is enough?
#97 weaponx
weaponx
  • 413 posts
  • LocationTX
Posted 15 February 2012 - 02:36 PM
same thing its happening to me, I've tried two restores and both failed. One I did with no wipe of data or cache, pretty much instant fail. Next, I wiped data and cache, got about 50% done, then failed. Wtf? Something is up, this should not be happen ing on a simple restore. It can't be our phones, either we are not doing something we should or we need some instructions on how to do a proper restore
Hey bub, I'm not finished with you yet..... SKNIT!!
#98 tweakhax
tweakhax
  • 46 posts
  • Google+:116149427927563718815
  • LocationSouth Dakota
Posted 15 February 2012 - 02:50 PM
Thanks nitro. GJ
Dedicated to preserving the art of the Crackflasher ---- Where's my stylus?
#99 Mral
Mral
Posted 15 February 2012 - 05:07 PM
Hi everybody, excuse me for the n00b question, but where are this bootstrap.apk file? After downloading and unzipping I see no apk file, so why I'm doing wrong? Thanks
#100 stupidchicken03
stupidchicken03
  • 104 posts
Posted 15 February 2012 - 08:12 PM
Go to the first post and click the link. It will download the Bootstrap.apk.. its not a zip file
+1 I would like a step-by-step on creating/deploying a backup
