[Recovery] Droid Razr Bootstrap Recovery *updated 2/8/12
201 replies to this topic
#61 DarkestSpawn
DarkestSpawn
    Tester
  • 211 posts
Posted 06 January 2012 - 06:58 AM
Thanks. But I thought for ROMs you should use Safestrap and for Themes you should use Bootstrap??? :)
Its up to the creator of the ROM or theme on how it should be installed.
-Beta Mod-
-Grand Master of the Testing-
#62 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 06 January 2012 - 07:14 AM
Yep, got it. Thanks!
#63 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
  • Twitter:@quadjacks
  • LocationFort Drum, NY
  • Current Device(s):Maxx HD
Posted 13 January 2012 - 07:09 PM
How do I properly un-install this?
#64 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 13 January 2012 - 07:33 PM
I followed the steps
and have uninstalled this 3 or 4 times with no issues at all. Just make sure that you follow every step and if you have any questions someone is always here to help.
  • quadjacks likes this
#65 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
Posted 13 January 2012 - 07:51 PM
Thanks!
#66 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 18 January 2012 - 08:19 PM
im having a small issue. I was running .748 and bigs ICS theme. i decided to test out the Rom selection, so i downloaded RazrX v1.1, i did a factory reset/wipe cleared cache, flashed the RazrX rom, got all my apps and everything set back up, OTA rootkeeper says im still rooted, all my other applications seem to be working, but RazrBootstrapper isnt showing in my app list, i located it on my sd card using root explorer, i clicked on it, and when trying to install, it just sits on the screen and will NOT let me choose to Install. i have deleted the file, re-downloaded and came up with the same thing, the install button will not let me press it. Same goes for safestrap, i downloaded that and tried installing, it opens up the screen when i click on the apk file, but again, it will not let me press on the Install button. Can anyone help me out with this, as of right now im all out of ideas....
#67 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 19 January 2012 - 05:14 AM
I installed Rom ToolBox and am able to boot into Recovery through it, which is great.. but it still is not showing razr bootstrapper in the app drawer. so if anyone can still help me fix that, that'd be great, but not in a big hurry as I can get into CWR now. shoots
#68 calebgreenwood
calebgreenwood
  • 10 posts
Posted 19 January 2012 - 02:00 PM
if i get stuck in a boot loop is there anyway to manually boot in to cwm?
#69 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 19 January 2012 - 02:02 PM
think ur to hit or hold the menu key at the splash screen to boot into recovery..
#70 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 20 January 2012 - 11:27 AM
Is there a problem with this app not being able to restore /system?
#71 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 20 January 2012 - 01:20 PM
Nope. Its your Razr. I had that issue with Safestrap, removed the recovery. Installed Bootstrap, couldn't restore /system/ either. RSD Lite and a wipe on first boot later...they both work fine with restoring. Not sure what happened to it, but yours is the same problem I've faced.
#72 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 20 January 2012 - 01:36 PM
Thanks bro..I'll chat with ya tonight on what to do..at work now. :/
  • Gaurang likes this
#73 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 20 January 2012 - 02:40 PM
I tried an advanced data restore and i'm back into Eclipse with all data from last night.lol
#74 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
Posted 20 January 2012 - 02:57 PM
I just manually backup/restore my messages database every time I do anything major to my phone. I don't want anything else from my phone saved... That's just me
#75 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 20 January 2012 - 03:23 PM
SMS Backup / Restore works great for that.
#76 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 20 January 2012 - 03:29 PM
Yep, this is what I use for messages. I do wish it backup/restore images too.
#77 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 20 January 2012 - 05:13 PM
Which is why I do a manual backup. Images etc are saved
#78 matsounds
matsounds
Posted 25 January 2012 - 08:46 PM
Works perfectly!!!!
I now have full control of my Motorola Razr!
Screw you Verizon and your crapware!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • ThaTwizzla likes this
#79 snives
snives
  • 947 posts
Posted 25 January 2012 - 09:01 PM
Works perfectly!!!!
Not quite. If you want full control, help out with demanding the unlocked bootloader from Motorola.
#80 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 26 January 2012 - 01:38 AM
Video of getting Bootstrap CWR on boot every time
  • mcjonesy likes this
