[Recovery] Droid Razr Bootstrap Recovery *updated 2/8/12
#41
Posted 20 December 2011 - 08:27 PM
#42
Posted 20 December 2011 - 08:33 PM
Yea I was able to get the update. I am not sure if its because I applied for the soak test and got the invite or not. But I have had no issues at all after following these steps. Since I am in on the soak test and have access to the private forums, I can take a look to see if there are any steps you could try. I know they have a thread for this issue.
I am part of the soak too, the update push would not work, so i did all the steps we did but the update was no longer being pushed to my phone....... i am going to re due everything and wait i guess, ....I also tried to flash the update that they talk about, but was also getting an error..... let me know if you have any ideas....
thanks,
Robert
#43
Posted 20 December 2011 - 08:35 PM
#44
Posted 20 December 2011 - 08:40 PM
#45
#46
Posted 20 December 2011 - 08:48 PM
Thanks... if you see anything let me know!
Robert
#47
Posted 20 December 2011 - 08:50 PM
#48
Posted 20 December 2011 - 08:56 PM
- Thach likes this
#49
Posted 23 December 2011 - 07:52 AM
We are moving them around to consolidate.
This will improve the chances of our members getting the prompt and accurate assistance they deserve.
Our members are number one and we will continue to provide you with the best Droid Razr experience possible
#50
Posted 29 December 2011 - 02:13 PM
#51
Posted 31 December 2011 - 09:08 AM
#52
Posted 31 December 2011 - 10:50 AM
I have used this successfully before, but today nothing is happening after I hit reboot recovery. I hit bootstrap recovery, then after it says success I select reboot, then nothing happens. I uninstalled the apk then reinstalled. Still nothing. Any ideas?
After uninstalling, try removing any sign of it then reinstall. The steps too completely remove it are posted a couple pages back. If you need any help just let me know.
#53
Posted 31 December 2011 - 09:30 PM
#54
Posted 01 January 2012 - 07:18 AM
#55
Posted 01 January 2012 - 07:29 AM
everything seems to be working now. Was able to back up system.
Good to hear. Anything special you did that you could share in the event that someone else has this issue or did it kind of fix itself?
#56
Posted 01 January 2012 - 07:36 AM
Sent from my Rooted Droid Razr
#57
Posted 01 January 2012 - 07:55 AM
#58
Posted 05 January 2012 - 10:24 PM
#59
Posted 06 January 2012 - 05:10 AM
Is this the correct Bootstrap to install for ROM's and Themes? Currently using Safestrap but no themes are for SS. So I want to go to Bootstrap with my rooted stock 748 and flash themes.
Yes, this is the original Bootstrap Recovery for the Droid RAZR. Make sure you uninstall Safestrap via the app, then install Bootstrap and bootstrap recovery.
Most new ROM's and themes are designed to work with Safestrap though.
-Grand Master of the Testing-
#60
Posted 06 January 2012 - 06:42 AM
Thanks. But I thought for ROMs you should use Safestrap and for Themes you should use Bootstrap???Yes, this is the original Bootstrap Recovery for the Droid RAZR. Make sure you uninstall Safestrap via the app, then install Bootstrap and bootstrap recovery.
