Droid Razr M AP Fastboot Flash Mode
droid razr crash battery fastboot root xposed
4 replies to this topic
#1 NakedJesus
NakedJesus
Posted 30 March 2015 - 01:09 PM
Hello, I am experiencing a problem that prohibits me from doing anything productive on my phone. I'm able to start it, but it only stays on for about 30 seconds, and goes to a screen which says:
AP Fastboot Flash Mode (S)
10.9B(*) (sha-1e9f557, 2013-05-29 13:50:43)
eMMC Info: Size 8GB
Device is LOCKED. Status Code:0
Battery OK
Connect USB
Data Cable
Failed to hab check for recovery: 0x56
Fastboot Reason: Boot Failure
          The phone is a Droid RAZR M, running Android 4.1.2, and my system version is 98.16.3.XT907.Verizon.enUS. I am rooted and I have Xposed. I tried both unrooting and uninstalling Xposed, but since that did nothing to ameliorate the situation, I think that the problem might be battery related. The thing is, I don't want to purchase another battery, and end up with a useless old phone with a new battery. I put it into the charger before going to bed, but I forgot to unplug it since it already had a 100% charge. When I woke up the next morning, however, it was hot and it was at the "AP Fastboot Flash Mode" screen. I decided to leave it alone for a day, but that didn't solve the problem at all. If the problem isn't battery related, then I'm trying to see if I can get the problem solved without doing a factory reset. Does anyone have any clue as to what's going on here?
#2 thewraith420
thewraith420
    Crack Flasher
  • 112 posts
  • Current Device(s):XT907 jbbl Blisspop
Posted 02 April 2015 - 06:15 PM
Use rsd and flash any stock firmware except 18x.46.15..... Whats happened is your locked bootloader detected a non stock recovery.....
#3 thewraith420
thewraith420
    Crack Flasher
  • 112 posts
Posted 02 April 2015 - 06:25 PM
If you flash 18x.46.10 you could safely unlock and flash a custom recovery
  • RikRong likes this
#4 NakedJesus
NakedJesus
Posted 07 April 2015 - 11:14 AM
Thanks for the help. Although I lost everything since I forgot to back up, my phone is working better now on the BlissPop 5.0.2 rom. If anyone else comes here looking for a fix, I used these two threads (in that order):
  • jibjabst likes this
#5 parattodos
parattodos
  • 15 posts
  • LocationSalvador
  • Current Device(s):Motorola Droid Razr M xt907/Motorola G XT1032/Samsung Jack i637
Posted 08 August 2015 - 04:04 PM
Any of you have office apk form jellybean of this xt907?
Also tagged with one or more of these keywords: droid, razr, crash, battery, fastboot, root, xposed
