droid razr xt912 auto reboot after hang every 2min
Best Answer johnthehillbilly , 03 April 2015 - 10:13 AM
http://www.droidrzr....-House-of-Moto-[4.1]
Make sure you read it completely and follow all the directions :) Go to the full post
23 replies to this topic
#1 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
  • Current Device(s):Motorola Droid razr xt912 cdma
Posted 27 March 2015 - 12:15 PM
I have reflashed it using rsd but no effect ... checked it on safe mod again no benefit
It just keeps freezing and then rebooting ... please help is it a software failt or hardware fault??
#2 johnthehillbilly
Posted 30 March 2015 - 05:11 AM
Did you completely wipe internal and external storage(s) prior to flashing?..... Also.... You may want to try flashing with the House of Moto instead of RSDlite.... Sometimes it works better for people :) :)
#3 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 03 April 2015 - 10:10 AM
yes i have wiped several times ....
and a link for that house moto.. software would be appreciated .... :)
Thanks for reply and sorry for my late reply
#4 johnthehillbilly
Posted 03 April 2015 - 10:13 AM   Best Answer
[4.1]
  • hamxamirxa likes this
#5 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 03 April 2015 - 10:17 AM
and yes please i have read this but couldnt understand how to flash :( plz help
#6 johnthehillbilly
Posted 03 April 2015 - 10:23 AM
What are you not understanding? ....
#7 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 03 April 2015 - 10:31 AM
Well right now my phone is bricked and giving battery low in Ap fastboot mod ... :p
i know how to unbrick it ... thats what iam doing right now ....
now in that thread i wanna know that how to run that Houseofmoto.jar ... ?
#8 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 03 April 2015 - 10:33 AM
got it ... download java 7 :p
#9 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 03 April 2015 - 10:34 AM
and hey do u know how to unlock bootloader of xt912 cdma ??? ;)
#10 johnthehillbilly
Posted 03 April 2015 - 10:37 AM
Ok.... Yes, java is what you need.... Low battery in fastboot will not allow flashing unless you get it charged or have a factory adapter (or cable)...... Unlocking the BL on the 912 is not possible
#11 jl90
jl90
    \m/
  • 1,642 posts
  • LocationPhoenix, Az.
Posted 03 April 2015 - 01:31 PM
John, you have the patience of a saint. LOL!
  • johnthehillbilly likes this
#12 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 03 April 2015 - 09:34 PM
Hey dont be beotchy ....
John  is a good person helping people like me (noobs)
john iam working on link given by you  :)
#13 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 03 April 2015 - 09:37 PM
and i charged my xt912 by connecting charger pins + and - of battery terminal .... and flashed 9.8 firmware with webtop of 6.16 firmware ... now will check if it doesnt works then i will flash with house of moto :p
#14 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 03 April 2015 - 09:39 PM
and some mechanics/software Engineers also said to me that I should change battery .... can battery cause a phone to hang & then reboot .... ?????
really confused about that part .... :/
#15 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 03 April 2015 - 09:59 PM
Low battery will cause an improper or incomplete flash of the firmware which will cause what you were talking about or right out brick the phone depending where it was in the process of the flash. If HOM doesn't flash it after the battery is charged then I would start looking at a hardware problem.
#16 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 04 April 2015 - 02:29 AM
Iam talking that some soft engs.... said that rebooting is caused by battery ..... iam confused about this ....
i can unbrick my phone i know about that all
And i tried to downgrade using moto house .... the some of flash files didnt flashed gave error preflash erro something like that but system and preflash.img were flashed succesfully and battery charging logo while phone turned off was changed
though mobile wasnt turning on !!
now trying some diff methods ...:p
#17 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 04 April 2015 - 03:17 AM
HEy all new thing..
I tried to downgrade using house of moto....
from 9.8ver firmware to 6.16 ver firmware
although it didnt flash
files like:- (Gave error Info preflash failure of something like that)
Ebr not found
Mbr not found
cdt.bin error Info preflash failure
devtree.bin error Info preflash failure (then flashed devtree of ver 9.8ver
boot.img error Info preflash failure ( then flashed boot.img of  ver9.8
recovery.img error Info preflash failure
After the flash completed through house of moto
the android logo came up loading something as it does always after a flash and my boot logo has also changed to dual core tech..
but the mobile doesnt boot to OS .... just blank screen
"and it can also charge while its turned off ( with a changed charging logo of firmware version of 6.16)
Easy talk : that i think there might be a chance of downgrading Droid razr xt912 cdma ... As, I have came this far ... :p
#18 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 04 April 2015 - 03:18 AM
and when there is blank screen after dual core technology logo....
the mobile can be found connected with adb via Cmd ... :/
#19 hamxamirxa
hamxamirxa
  • 27 posts
  • LocationPakistan
Posted 04 April 2015 - 03:46 AM
ok now simply flashed version 9.8 4.1.2 JB via house of moto
error: cannot load 'cdt.bin_signed'
     rebooting into bootloader... OKAY [  0.016s]
     rebooting into bootloader... OKAY [  0.000s]
< waiting for device >
        sending 'mbm' (512 KB)... OKAY [  0.051s]
                 writing 'mbm'... OKAY [  0.494s]
     rebooting into bootloader... OKAY [  0.296s]
   sending 'mbmloader' (42 KB)... OKAY [  0.010s]
           writing 'mbmloader'... OKAY [  0.291s]
        sending 'mbm' (512 KB)... OKAY [  0.312s]
                 writing 'mbm'... OKAY [  0.484s]
     rebooting into bootloader... OKAY [  0.281s]
Flash MotoBoot partition? [y/n]: y
  sending 'motoboot' (2561 KB)... OKAY [  0.250s]
            writing 'motoboot'... INFOerasing flash
INFOwriting flash...mbr
INFOskipping...mbr_8G...not for this hw
INFOerasing flash
INFOwriting flash...ebr
INFOskipping...ebr_8G...not for this hw
INFOerasing flash
INFOwriting flash...cdt.bin
INFOskipping...cdt.bin_8G...not for this hw
INFOskipping...logo.bin...restricted
OKAY [  1.622s]
               erasing 'cache'... OKAY [  1.466s]
WARNING: Choosing yes to this option will WIPE YOUR DATA.
Erase userdata partition? [y/n]: y
            erasing 'userdata'... OKAY [  1.342s]
            erasing 'userdata'... OKAY [  0.905s]
   sending 'logo.bin' (854 KB)... OKAY [  0.078s]
            writing 'logo.bin'... OKAY [  0.343s]
    sending 'devtree' (512 KB)... OKAY [  0.296s]
             writing 'devtree'... OKAY [  0.515s]
  sending 'system' (262144 KB)... OKAY [ 24.782s]
              writing 'system'... OKAY [ 10.862s]
  sending 'system' (262144 KB)... OKAY [ 24.768s]
              writing 'system'... OKAY [ 10.343s]
  sending 'system' (130816 KB)... OKAY [ 12.346s]
              writing 'system'... OKAY [  5.199s]
      sending 'boot' (8192 KB)... OKAY [  0.702s]
                writing 'boot'... OKAY [  0.952s]
  sending 'recovery' (9216 KB)... OKAY [  0.952s]
            writing 'recovery'... OKAY [  0.936s]
error: cannot load 'cdrom'
sending 'preinstall' (262144 KB)... OKAY [ 24.748s]
          writing 'preinstall'... OKAY [ 10.737s]
sending 'preinstall' (262144 KB)... OKAY [ 24.829s]
          writing 'preinstall'... OKAY [ 10.275s]
sending 'preinstall' (98304 KB)... OKAY [  9.300s]
          writing 'preinstall'... OKAY [  3.884s]
    sending 'radio' (21912 KB)... OKAY [  1.951s]
               writing 'radio'... OKAY [  2.202s]
                     rebooting...
Rebooting...
Thanks for using the House of Moto.
DO u think its a right flash ????
#20 johnthehillbilly
Posted 05 April 2015 - 06:39 AM
I have told you, you CANNOT downgrade the 912 .... Also, if you just start flashing "random" firmwares you can and will permanently destroy your device period....
  • jl90 likes this
