[ROM][5.0.2][AOSP] AOD-dark
1 reply to this topic
#1 mrlolli
mrlolli
    Put Member Title Here
  • 763 posts
  • LocationNowhere
Posted 26 March 2015 - 09:53 PM
Basically out of the box AOSP.
Nothing dirty or blissful about this,
just simply simple
with the basic features to get you through the day
Attached File  Screenshot_2015-03-25-00-34-40.png   105.74KB   4 downloadsAttached File  Screenshot_2015-03-27-01-32-01.png   39.31KB   4 downloads
This rom flashed and worked fine on my phone.  If for some reason it blows your phone up, it ain't my fault.  By clicking the download button, you are assuming all risks associated with flashing a ROM.
Thanks go out to:
nobe1976
Google
the AOD team
my tester
TLS
Bugs:
dialer occasionally FC's when using the search function in the phone app
please fill me in on any others :)
Install:
Be sure you are running a lollipop capable version of cwm or twrp
Wipe system, data, and cache
Install rom
Install your choice of 5.0 GAPPS
Reboot
note: this rom will flash fine as a secondary rom on multirom
Changelog:
-- Added Dark Material for a Darker experience.
-- Fixed init.d scripts not loading on reboot
-- Fixed some minor Bluetooth issues..
-- Added ability to tap on Statusbar Time to open Clock
-- Added ability to tap on Statusbar Date to open Calendar
-- Adjusted some internal device specific configs.
-- Speed things up a bit (Thanks Team DU..)
-- Added Double-Tap-Statusbar to sleep Option in Display Settings (On By Default)
-- Added Close all Recents
-- Kill app Longpress Back on Nav. (Optional in Developer Settings)
-- Minor updates to performance and Battery like..
Changelog
-- Added in 1% Battery avaiblility
-- Added in Volume key Music Skip (Turned on by Default)
-- Added in Gesture Status bar brightness control
-- Added in Center Clock Mod and Color
-- Added in Notification and Battery Light Mod
-- Added in Device Profiles
-- Added in Ambient display (You can disable it in Display Settings)
-- Added fix for Status bar location icon always on...
-- Optimized for speed
-- Added Super Su into the rom updater
-- Some additional pre-theme adjustment.
-- Undercover work (To many other changes to list. HAHAHAHA.)
Last but not least, the download:
03.26.2015: http://teamlitespeed...on-20150326.zip
Thanks for checking this out, and I hope you enjoy it! :)
  • prstorero, rickw, Bama and 2 others like this
Nice job on the signature, jl90...thanks!
#2 adens
adens
  • Current Device(s):KC-S701..Torque
Posted 27 January 2016 - 10:45 PM
Thank you
