Bluetooth on ICS causes freeze and reboot
bluetooth
3 replies to this topic
#1 mobilechrisd
mobilechrisd
  • 10 posts
Posted 10 January 2013 - 09:51 AM
Since the update to ICS (any build and any ROM), my Bionic will randomly freeze and then reboot when it is connected to bluetooth.
I have found the issue in Motorola's forums here:
and it seems that it is a known issue and Verizon Tech Support says it is a known issue.
Motorola Tech Support wants me to send the phone in for repair (under warranty).
Has anyone been able to solve this issue? Will sending it in for repair help? I don't want to jump through Motorola hoops and only end up back at square one.
Thanks,
Chris
#2 nitephlight
nitephlight
  • 82 posts
Posted 10 January 2013 - 10:24 AM
this occurs on stock ICS 246 as well? if so, that might be hardware/driver. most ROMs are CM or AOKP based and have known bluetooth issues.
a phone self-reboot is typically due to a kernel panic (sometimes due to OOM situations). this is low level stuff as the motorola forum post indicates- have you tried using a bluetooth tether to another device and seeing if it crashes as well? that would isolate the problem to the streaming protocol at least.
#3 mobilechrisd
mobilechrisd
  • 10 posts
Posted 10 January 2013 - 11:40 AM
Yes, this occurs on the ICS 246 OTA as well.
I have not tried the tether as you asked. I'll connect it tomorrow so I can have some extended time connected.
Chris
#4 mobilechrisd
mobilechrisd
  • 10 posts
Posted 11 January 2013 - 06:39 AM
Chris
I have been tethered to my laptop for over 1.5 hours now without issue. I usually get the forced reboot within 30 minutes.
You may have something there with the streaming.
Are there any custom kernels out there that may provide a solution?
Thanks,
CD
