I am having an issue with activating my sim card on the Verizon network on my Droid Razr M. I have tried multiple times removing the sim card while the phone is off and re-inserting it.. My phone is rooted. I tried taking it to the verizon store just a few hours ago to get a new sim card and have them activate it on my number. but as soon as they put the sim card in, they said that my phone de-activated the sim card.. they tried with three different cards.. and the conclusion that they had came to was that because my phone was rooted, that activation with sim card was impossible.. that it couldn't be done.. is this possible. will root cause my phone to not be activated? if so, is there any way around it? like unlocking the sim, or activating my number without the sim card? or would i have to completely unroot my phone and then go back into verizon?
Verizon Droid Razr M Sim Card Activation
Posted 18 March 2015 - 04:31 PM
Posted 18 March 2015 - 05:48 PM
- xKroniK13x likes this
Posted 18 March 2015 - 06:21 PM
Posted 19 March 2015 - 06:01 AM
The Verizon technician told me that if I could get it back to factory settings like they could activate it. Can I create a system IMG of my current ROM and all my rooted settings so I can unroot and factory reset and activate then clash my IMG back over? Or can I just take the screws off the sides and troubl eshoot the sim card tray??
Since in another thread you indicated that you were unlocked, in TWRP just make a backup and then factory reset your phone. When you get back restore the backup. If you are on a stock ROM and rooted, it really will not make a difference rooted or unrooted, but if VZW wants to try that, by all means. Taking the screws out will void warranty, but since its already voided/unlocked, that is your prerogative. Probably not much to see with the Sim tray though, but tearing things apart is always fun.
Sent from my Blissful RAZR M 5.0.2 from Tapatalk
Posted 19 March 2015 - 05:47 PM
Posted 19 March 2015 - 05:56 PM
It's because you need to use a .IMG in rashr or flashify. Just extract it from the .zip. You are for sure on stock ROM if you don't have a custom recovery installed.I don't believe I'm on stock rom. I was instructed to flask KitKat 4.4.2 in order to unlock my bootloader and I can't successfully get TWRP to install on my phone I've tried downloading the zip directly phone my phone and using Flashify and Rashr. I've also tries using RSD Lite and flashing it but it says the file is jot supported
Posted 20 March 2015 - 08:16 AM
Posted 20 March 2015 - 08:18 AM
My stock ROM was 4.1.2 when I recieved the phone. then I was told to download and flash 4.4.2
But the 4.4.2 was a stock one, stock just means developed and deployed by Motorola for your device.
Posted 20 March 2015 - 08:21 AM
Posted 20 March 2015 - 08:29 AM
Oh okay.. So I'll extract the IMG file and try flashing using Flashify but every time I tried installing any type of custom recovery when I boot into recovery mode I get stuck at the screen where it says warning your bootloader is unlocked
Don't allow Flashify to automatically download. Our device doesn't have an official TWRP. Download the latest TWRP zip file, unzip it to get the .IMG. Open Flashify, choose to flash a recovery, choose select file and navigate to the .IMG, not the .zip. Then reboot to recovery (Flashify has an option to do that).
- ccstone likes this
Posted 20 March 2015 - 09:18 AM
where does it save the backup to and if I factory reset won't I loose my back up file on my phone
Posted 20 March 2015 - 09:39 AM
Yea I downloaded twrp 2.8.5.0 from this forum. And extracted the IMG file and flashed it. And it worked now when I create a back up using TWRP
You choose where it saves. I created a folder on my SD card for backups. Depending on where you save it, a factory reset may wipe it out... Be safe a throw it on an SD card if possible, or create a folder at the root of your filesystem for them.
Posted 20 March 2015 - 11:07 AM
Posted 20 March 2015 - 11:29 AM
Okay so factory reset does not reset my SD card correct?
Correct. If you really want you could remove it and then factory reset. I've reset mine a ton of times with it in though.
Posted 20 March 2015 - 11:41 AM
Posted 20 March 2015 - 11:48 AM
Posted 20 March 2015 - 12:53 PM
Okay soive created a backup using TWRP and saved it to my SD card. Now while in TWRP, I go to reset and then advanced setting and it says wipe cache, data, davlik or something like that, and internal storage, system, then SD card. can i format everything except my SD card and it'll all go right back to factory settings right?
If you do that, your phone will be 100% wiped and will boot directly to recovery. There is an option in TWRP for factory reset, its in wipe somewhere. Or just go to settings on your phone and factory reset it.
Regarding your bootloader, it is permanently unlocked. If you want it to appear locked for VZW, flash the default boot image. Search Google for that, its cake.
Posted 20 March 2015 - 12:54 PM
Posted 20 March 2015 - 12:57 PM
Posted 20 March 2015 - 01:06 PM
It will just flashed the boot image of Motorola instead of the warning sign right
Yes, it will just make it appear locked. It will not relock it.
I wanted to ask something I went to setting and went to updaye . and it toldmea newer version other than 4.4.2 is available. Would it be OK to upgrade or No
It will fail because you don't have the default recovery.
Honestly, Your best bet if you want a 100% "retail" firmware, download it and do a full wipe install with House of Moto or RSD Flasher. This will revert everything, including your recovery. Take it to VZW, have them do what they need to, come back home, flash recovery through fastboot and restore your backup.
Also tagged with one or more of these keywords: Droid, Razr, SIm card, Activation
