Need help with a XT926M.
Would like to root, change roms, etc.
Where can I find instructions for this phone?
Motorola droid Razr Maxx HD, V 4.1.2, 9.18.94: see attached photo.
dlw
Posted 14 March 2015 - 09:49 AM
dlw
Posted 14 March 2015 - 10:35 AM
Thank you for replying.
[ROOT/UNLOCK]-4.4.2-182/183.46.10-RAZR-HD/M-*ONLY*
The word 'ONLY' scares me.
Are you sure this will work for my phone?
The reason I ask it I have a SCH-I705 Galaxy Tab 2 that is bricked by using a method for a deffernt Tab 2.
dlw
Posted 14 March 2015 - 11:49 AM
Thank you, I'll give it a go.
Posted 14 March 2015 - 12:24 PM
Is doing the attached going to upgrade my phone to 4.4.2?
Posted 14 March 2015 - 12:27 PM
Posted 06 April 2015 - 10:33 AM
The phone is rooted.
The following is the resutlt of running run.sh.
dlw@dlw-HP:~/motopocalypse$ ./run.sh
[*] Motopocalypse: Motorola bootloader unlock script (Linux/OS X version)
[*] v1.0
[*] Supports the Motorola Razr HD, Razr M, Razr Maxx HD, and Atrix HD.
[*] Before continuing, ensure that your device has been rooted and you have
[*] a working su installation, that USB debugging is enabled,
[*] and that your phone is connected via USB.
[*] WARNING: This will permanently void the warranty on your device. This
[*] is not reversible. I am not responsible for any damage to your phone
[*] as a result using this tool.
[*] Press enter to unlock your bootloader...
chmod: cannot access ‘.adb.linux’: No such file or directory
./run.sh: line 64: .adb.linux: command not found
[*] Waiting for device...
./run.sh: line 67: .adb.linux: command not found
[*] Device found.
[*] Pushing unlock tool...
./run.sh: line 72: .adb.linux: command not found
./run.sh: line 73: .adb.linux: command not found
[*] Unlocking phone...
./run.sh: line 76: .adb.linux: command not found
[*] Cleaning up...
./run.sh: line 79: .adb.linux: command not found
[*] Unlocking complete. Rebooting into bootloader mode.
./run.sh: line 82: .adb.linux: command not found
[*] Press enter once the phone has rebooted into bootloader mode.
.adb.linux is in the same directory.
adb is installed on the ubuntu pc.
Any help appreciated.
dlw
