[FXZ] VRZ XT1103 5.1 SHAMU LMY47E
FXZ N6 Shamu
20 replies to this topic
#1 livinginkaos
Posted 13 March 2015 - 01:24 PM
Here is a link to the Verizon Nexus 6 Variant LMY47E
They have different radios than the LMY47D found on the Google Factory images.
#2 Vicious
Vicious
    Baddassocity in a bottle
  • 67 posts
  • Current Device(s):LG G2 VS980
Posted 13 March 2015 - 08:42 PM
You have to use mfastboot to flash these files. Motorola uses bigger files than fastboot allows, which is why they use a modded version. I do not have a link to the file, but I believe that it can be found on motodev. After locating motorola fastboot, make sure to copy it to the location that you unzipped these files to. Connect your phone to your computer, and put it into bootloader mode by pressing and holding power + vol dn. Open command prompt as administrator, and change to the directory that you unzipped these files to. Make sure that mfastboot.exe is in there as well. Once there, type these commands:
mfastboot flash motoboot bootloader.img
mfastboot flash radio radio.img
mfastboot flash boot boot.img
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk.0
mfastboot flash system system.img_sparsechunk.1
mfastboot flash system system.img_sparsechunk.2
mfastboot flash system system.img_sparsechunk.3
mfastboot flash system system.img_sparsechunk.4
mfastboot flash system system.img_sparsechunk.5
mfastboot flash system system.img_sparsechunk.6
mfastboot flash cache cache.img
mfastboot flash oem oem.img
Now, when I did this, everything seemed to go just fine except for oem.img. It said it went well in command prompt, but on the log on the phone I got an error saying partition size mismatch. I'm not sure if it went through or not. Make sure that after booting up for the first time that you enable dev options by tapping on build number until says it's enabled, and check enable oem unlock. Also make sure to do this on your current rom before fashing any of this. There have been a number of folks that have put their device into a bootloop that they cannot get out of because oem unlock was not checked prior to flashing.
EDIT 1: This is running pretty amazing right now. It is buttery smooth, and is blazing fast. My Verizon and Visual Voicemail are the only two Verizon apps that I see. I am stock rooted and the boot loader is still unlocked. I just need to check to see if exposed works now.
Edit 2: I'm sorry I didn't catch this earlier, but the system files should definitely be flashed to the system partition, not recovery. Edited post to reflect this.
#3 Vicious
Vicious
  • 67 posts
Posted 16 March 2015 - 05:38 PM
Fixed error in last post where I had the system files being flashed to recovery. My apologies.
#4 cmh714
Posted 16 March 2015 - 05:44 PM
xposed wont work with 5.1....at least yet
#5 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 27 March 2015 - 02:36 PM
Interesting.
Is there a Specific image for the GPE?
#6 Vicious
Vicious
  • 67 posts
Posted 27 March 2015 - 03:03 PM
Interesting.
That is the version I have. All of the builds are the same except for minor changes to the modem files for the carriers. 47D seems to be the universal release. 47E is Verizon's build. 47I is the international build. 47M is the T-Mobile build. They'll all work with one another, and likely get merged into one build that includes all of the modem enhancements eventually. At least that is the theory.
  • johnlgalt likes this
#7 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 27 March 2015 - 03:10 PM
But, to prevent nasty litttle gremlins from coming out at me, since I have the GPE I should (theoretically) stick to the GPE specific build.
Screw it.  I've never been one to follow the beaten path.  Onwards and Upwards to "i" it is.
Right After I get unlocked.
Which means tomorrow.  LOL.
#8 cmh714
Posted 27 March 2015 - 03:21 PM
i is the latest/greatest and has some minor updates according to the change logs....it has the 95 version of the radio. the E version which is what came with Verizon phones has a 98 version of the radio.....some say they have seen better with one or the other so you may want to try both radios. personally I didnt see any difference here in L.A. YMMV
#9 Vicious
Vicious
  • 67 posts
What carrier are you on?
#10 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 01 April 2015 - 06:41 AM
VZW - phone isn't even activated at this point.  I think I am going to have to fool the system with a used VZW device that also uses that nano SIM.
*Conspiracy theory* They are refusing to let me bring my own device to their table because they are going to try to force me into a new contract and make me lose my unlimited data....
#11 livinginkaos
Posted 01 April 2015 - 06:54 AM
That's how it's done.
#12 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 01 April 2015 - 08:05 AM
Trying to decide.  Cut my SIM from my S3, buy a cheap device that uses a nano SIM and activate the nano I already have and then transfer it to my Nexus, or....
#13 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 01 April 2015 - 08:44 AM
They have a new moto e out that is cheap.  I don't know if verizon is selling it yet though.  They do have pre-owned phones on their website too. Also they didn't give me a minutes problem with my verizon xt-1060 de. That is a good way to go. They are fairly inexpensive on ebay.
#14 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 01 April 2015 - 09:14 AM
I have a buddy on an old RAZR anyway, so that might end up being the better way to go....
#15 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 01 April 2015 - 09:32 AM
It will have to be a 2013 model or newer to have the nano sim.  My xt-926 has a micro sim.  My 2013 Moto X DE has a nano sim.
#16 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 01 April 2015 - 09:34 AM
No, I meant that I could buy a cheap phone that uses a nano SIM, activate it, put the SIM in my N6, and give him the cheap phone which, for him, would be an upgrade.
Sorry for being obtuse there....
#17 zalabou
zalabou
  • 6 posts
Posted 03 October 2015 - 02:29 PM
hi every body, how i can flash this stock rom on nexus 6 locked bootloader, mine is no os, no recovery, just fastboot mode?
#18 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 03 October 2015 - 07:39 PM
Factory images for the nexus 6 and flashing instructions here https://developers.g...id/nexus/images
I would suggest since there will be quite a bit of flashing going on that you setup House of Nexus and use that.  Also Marshmellow comes out monday.  And while at the fastboot menu with nothing to loose on the phone it would be a good idea to unlock it. Unlocking does wipe the user data so flashing android and setting up before unlocking just makes you setup again after.  Good idea to remove the sim, flash and setup then insert the sim and let it activate.
#19 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 04 October 2015 - 03:50 AM
Once unlocked you can keep data going forward. I've kept data between all the M previews.
sig by jayrod
The Rules-Follow them.
#20 zalabou
zalabou
  • 6 posts
Posted 04 October 2015 - 12:16 PM
but how i can flash any think! i have a locked bootloader with no os, no recovery!
Also tagged with one or more of these keywords: FXZ, N6, Shamu
