Question i updated to 5.1 and now i am stuck on Google with lock any help can get to AP Fastboot but can not load factory image.
thanks for any help
Posted 25 May 2015 - 01:37 PM
thanks for any help
Posted 25 May 2015 - 01:55 PM
target reported max download size of 536870912 bytes
sending 'bootloader' (3807 KB)...
OKAY [ 0.136s]
writing 'bootloader'...
(bootloader) flashing partition ...
(bootloader) This may take a few seconds if a
(bootloader) different partition table is being
(bootloader) flashed since we need to backup
(bootloader) and restore a few partitions
(bootloader) Flashing primary GPT image...
(bootloader) Flashing backup GPT image...
(bootloader) flashing aboot ...
(bootloader) flashing sbl1 ...
(bootloader) flashing rpm ...
(bootloader) flashing tz ...
(bootloader) flashing sdi ...
(bootloader) flashing logo ...
OKAY [ 0.471s]
finished. total time: 0.609s
rebooting into bootloader...
OKAY [ 0.003s]
finished. total time: 0.004s
< waiting for device >
sending 'radio' (85427 KB)...
OKAY [ 3.009s]
writing 'radio'...
(bootloader) flashing modem ...
(bootloader) flashing mdm1m9kefs1 ...
(bootloader) flashing mdm1m9kefs2 ...
(bootloader) flashing mdm1m9kefs3 ...
(bootloader) flashing versions ...
OKAY [ 2.042s]
finished. total time: 5.057s
OKAY [ 0.003s]
finished. total time: 0.003s
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
failed to allocate 1778054096 bytes
error: update package missing system.img
Press any key to exit...
Posted 25 May 2015 - 02:13 PM
How was you trying to flash the image?
If you were using the stock flashall.bat look at this: http://phandroid.com...stem-img-error/
Posted 26 May 2015 - 03:35 AM
Or even better and a bit easier grab the House of Nexus created by our illustrious Samuri and use that to install the OS (but be sure to read, read and read again all the instructions in the first post).
