My first go at flashing and my xt925 is a brick.
1 reply to this topic
#1 minisman
minisman
  • LocationAustralia
  • Current Device(s):xt925
Posted 06 March 2015 - 04:57 AM
Hi Samuri and others.
I have read heaps of posts trying to find an answer to my problems, but it seems that i might fix one and then another issue pops up.
Situation is I have an xt925 bought through Telstra in Australia. we are STILL stuck on 4.1.2 with no updates, I heard that I could flash the australian retail 4.1.2 and then get OTA update to 4.4.2. So that was my plan.
I stupidly didn't record any detalis about the current flashing on the phone, I just know it was 4.1.2.
I read a bunch of forums and thought I could get away with flashing my phone with RSD lite without unlocking the bootloader. So I tried it.
I had it fail on step 16/22 flashing System
Since then I have all sorts of errors, I have tried all sorts of utilities including HoM to fix it.
Once I get past the sticky bit error and clear it, I get the No Valid PIV.... error
So now I'll get onto my using HoM... I'm doing lots of bad things, firstly i damaged the motorola cable, so I trying all different ones I have lying around. secondly my computer is old and gutless.
When I try to flash the files I have using HoM it doesn't seem to even try half the steps with variable not supported bit.
I think it might be something simple but below is the print out.
C:\HouseOfMoto\MOTO>flashme.bat
(bootloader) Variable not supported!
target max-download-size: 30MB
error: cannot load 'partition_signed': Unknown error
error: cannot load 'sbl1_signed': Unknown error
error: cannot load 'sbl2_signed': Unknown error
error: cannot load 'sbl3_signed': Unknown error
error: cannot load 'rpm_signed': Unknown error
error: cannot load 'tz_signed': Unknown error
error: cannot load 'aboot_signed': Unknown error
error: cannot load 'modem_signed': Unknown error
error: cannot load 'fsg_signed': Unknown error
erasing 'modemst1'...
OKAY [  1.234s]
finished. total time: 1.234s
erasing 'modemst2'...
OKAY [  1.234s]
finished. total time: 1.250s
error: cannot load 'logo': Unknown error
error: cannot load 'devtree_signed': Unknown error
error: cannot load 'boot_signed': Unknown error
error: cannot load 'recovery_signed': Unknown error
error: cannot load 'system_signed': Unknown error
error: cannot load 'cdrom_signed': Unknown error
erasing 'tombstones'...
OKAY [  1.766s]
finished. total time: 1.781s
erasing 'cache'...
OKAY [  2.406s]
finished. total time: 2.422s
WARNING: Choosing yes to this option will WIPE YOUR DATA.
Erase userdata partition? [y/n]: y
erasing 'userdata'...
OKAY [  5.906s]
finished. total time: 5.906s
rebooting...
finished. total time: 0.000s
Rebooting...
Thanks for using the House of Moto.
#2 minisman
minisman
  • LocationAustralia
Posted 06 March 2015 - 05:01 AM
Oh yeah and the 2 files I have tried flashing with have been:
I have no idea what these are, I just know they are both Australian, one is Telstra (which I think my phone was on before I bricked it) and the other is unbranded Australian build.
