Kill Rom
#1 Guest_HOFFA_*
Posted 03 January 2013 - 12:32 AM
Here it Is, Kill Rom Is Here. Use @ Your Own Risk.
- chakuza likes this
#2 Guest_HOFFA_*
Posted 03 January 2013 - 12:37 AM
#3 Guest_HOFFA_*
Posted 03 January 2013 - 12:47 AM
#4 Guest_HOFFA_*
Posted 03 January 2013 - 12:52 AM
#5 Guest_HOFFA_*
Posted 03 January 2013 - 01:08 AM
#6 Guest_HOFFA_*
Posted 03 January 2013 - 01:19 AM
Posted 03 January 2013 - 04:21 AM
sent from my icy bionic
- blazo likes this
Posted 03 January 2013 - 05:50 AM
Posted 03 January 2013 - 06:09 AM
Needs gapps? Does tether work?
From what I have read the gapps are built in. Don't know about tether yet.
Puff the Magic Dragon
Posted 03 January 2013 - 06:32 AM
Posted 03 January 2013 - 07:01 AM
Does anyone else have an issue with the menu key backlights staying on even while the screen is locked?
Have you tryed going into display under brightness check brightness hit ok then go back in there uncheck brightness then ok should work did for me. I know it's a lot to do but.......
Posted 03 January 2013 - 07:30 AM
I just tried that, but the lights still remain lit even while the screen is off.
Posted 03 January 2013 - 08:22 AM
Well I'm sorry I thought it would work it did for me..
#14 Guest_HOFFA_*
Posted 03 January 2013 - 08:54 AM
no gapps and tether does work.Needs gapps? Does tether work?
Posted 03 January 2013 - 09:23 AM
Had same issue. No amount of toggling would get rid of it.
Posted 03 January 2013 - 09:29 AM
Posted 03 January 2013 - 11:14 AM
Sent from my DROID BIONIC using Xparent Blue Tapatalk 2
Posted 03 January 2013 - 11:21 AM
Same issue here too.. ROM runs smooth as butter. Cannot get the key backlights to turn off..
Posted 03 January 2013 - 11:23 AM
Is this slot 1 only ?
Yep.
Posted 03 January 2013 - 11:25 AM
Toggle auto brightnessSame issue here too.. ROM runs smooth as butter. Cannot get the key backlights to turn off..
