[ROM] Hatka DNA 2.0.0 [1/2/13] Battery life | AC!D Audio | Bravia |Sense 4+
5 replies to this topic
#1 MustafaHadaKing
MustafaHadaKing
    Developer
  • 15 posts
  • Locationboston
  • Current Device(s):Htc Droid DNA
Posted 02 January 2013 - 05:32 PM
***NOTE*** to get Photosphere working i had to change the build prop of the phone, so it says the phone is running 4.2(really running 4.1.1) and the phone is a galaxy nexus.(Really a Droid DNA lol)
♦ Based On Verizon DNA 1.15.605.4 Rooted/Deodexed/Semi-Debloated/Busybox (Thanks MyComputerDoctor)
♦ Removed Permanent WIFI Status Bar Pop-up
♦ Added 4 in 1 Reboot Options
♦ Added HTC Flashlight (Thanks dsb9938)
♦ Added Superuser App
♦ Removed NFC Status Bar Notification Icon
♦ Added Busybox
♦ Zipaligned all APK's
♦ Removed all HTC Bloat
♦ Fixed SD-Card Permission Errors
♦ Fixed Camcorder Force Closing Issue
♦ Android 4.1.1 / Sense 4+
♦ enabled custom recent apps actions in "display, gestures, buttons" (From UKB)
♦ removed ics/jb 3 dot legacy menu, and changed dimensions so its not blank space in apps ( From UKB)
♦ Removed Boot Sound
♦ Added Several Build Prop Tweaks For Better Battery Life And Speed
♦ Added Several Init.D Tweaks For Battery Life And Speed
♦ Ac!d Audio Engine
♦ Bravia Engine
♦ %Battery Bar (From UKB)
♦ Semi Transparent Status Bar (From UKB)
♦ Added lyapota's camera mod (Thanks lyapota)
♦ 4.2 camera, clock, keyboard
♦ Blocked Ads
♦ Working Photosphere
♦ Landscape Rosie
♦ Better 4g/3g
♦ Smoothness tweaks
♦ Speed Tweaks
♦ Might have forgot some minor tweaks and mods
♦ MAKE A NANDROID BACKUP BEFORE FLASHING ANYTHING!
♦ Download Boot.img To Computer
♦ Download the Rom On your Phone
♦ Go on your computer
♦ Go to command prompt or terminal
♦ Type
♦ "Adb Reboot Bootloader"
♦ Once your in BootLoader Type in this Command
♦ "Fastboot Flash Boot (Where You Put Your Boot.img)
♦ Now Go into Revocery ( I have only tested this in CWM, so if someone will test this in TWRP that would be helpful)
♦Full Wipe
♦ Flash The Rom
Whole UKB Team ♦ Because i took mods from UKB
nitsuj17 ♦ Made UKB
jcase ♦ for unlocking the DNA
lyapota ♦ for original camera fix, long-press back to kill app
ibotpeaches ♦ for ics + apktool
brut.all ♦ for original apktool
shnizlon ♦ for wipe script that doesnt touch internal storage, pointers on alt apm
dsb9938 ♦ for resizing the rezound flashlight app
x3demond3x ♦for framework fix for deodexed camera fc
m0narx ♦ for custom gps configs in aroma
jotha ♦ for one x jb apm mod that I adapted for the dna
turge ♦ for his help with rosie on screen menu and everything else
rwc95 ♦ for original rezound persistent notification wifi notification removal
one_love_420 ♦ for parts of his evo lte apm that I adapted (1.2.0+_
zarboz ♦ for original mod for wake on volume deep sleep
andybones ♦ for bringing the mod to the inc4g
O.M.J. ♦ for evo lte modpack which I looked over and used a script from
qd2dc ♦ for his help and someone to bounce ideas off of
chainsdd ♦ for superuser
MyFishBear ♦ Tooks some of Mods from his ROM
MyComputerDoctor ♦ for letting me base my Rom of his
Sony ♦ Bravia
Knight47 and the AC!D Audio Team ♦ AC!D Audio
b16 ♦ (for the System Dump)
x3deamon3x ♦ (Disable WIFI Nag)
Chingy051 & Newtoroot ♦ Took a mod from CODIS
dr_drache ♦ Fixing Ac!d Audio bugs
anyone else I may have forgotten
Hatka DNA 2.0.0
boot.img
please tell me what to add and what to remove, i am very flexable and will try to fit your needs for the most part :)..
Note i am not responsible for anything that happens to your device, but if anything goes wrong i will try to assist you.
If you like the ROM it would mean alot if you hit the thanks button
♦ Get Cubed Kernel! [Dsb's Kernel is amazing and will improve your battery by at least 10%]
♦ If you turn off standalone GPS service u get way better battery life. You can use the Power Widget and do it.
♦ There are some further tips on CODIS ROM's Thread
Posted Image Posted Image
ChangeLog
1.0.0 - First Build
1.1.0 ♦ Fixed bugs
1.2.0 ♦ Fixed Boot Problems
1.3.0 ♦ Fixed Root Issues, Audio bugs, added 4.2 apps ( stock browser, camera, gallery, keyboard)
1.3.2 ♦ Re added HTC Apps, Added Landscape Rosie support, Added Speedscript(thanksMyfishbear), Added Working Photosphere.
1.3.2 ♦ Bug Fixes
2.0.0 ♦ Less UKB is being used, + Added Quick Launch Widget
  • mattlgroff likes this
#2 MustafaHadaKing
MustafaHadaKing
    Developer
  • 15 posts
  • Locationboston
Posted 02 January 2013 - 05:34 PM
reserved
#3 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 03 January 2013 - 06:56 AM
Nice to see you here! I will let people know your here! Thanks for coming! Let me know if you need anything. We hold a hangout every Saturday at 10pm EST time if you would like to join and introduce yourself and get to know our staff.
#4 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 03 January 2013 - 10:25 AM
Welcome good Sir... Thank you for breathing some life into our DNA area...
#5 djhbomber1
djhbomber1
  • 47 posts
  • Current Device(s):OG Razr, Razr MAXX HD
Posted 04 February 2013 - 01:18 PM
Good lord, look at those Quadrant scores!
#6 shizumie
shizumie
  • 650 posts
  • Google+:shizumie@gmail.com
  • LocationHortens, Ga
  • Current Device(s):DNA
Posted 08 February 2013 - 09:01 AM
Nice rom, This is what ive got on mine as of this morn, with cubed kernal. So far very nice, waiting a day or two to guage battery. Im about to put viper on my wifes.
Also thanks to Mustafa for bringing this to all DNA's and to DroidRZR!
