![](http://www.gravatar.com/avatar/842370f8cde22880adeb978f7946ee94?s=100&d=http%3A%2F%2Fwww.droidrzr.com%2Fpublic%2Fstyle_images%2Fdark_matter%2Fprofile%2Fdefault_large.png)
Best Answer Jbirdy10 , 26 February 2015 - 04:52 PM
Once I got BL unlock, I started trying some Lollipop. Early builds worked good with a typical five minute first boot. At some. Point (builds around Christmas time), I started seeing the same problem. Screen on reboot - blank. Did the same thing booting into TWRP. The only thing that worked for me (requires an internal sd wipe - no fun). Changed file format to ext4. Performed "advanced" wipe, from then on (everything but internal and external sd). Since then, most new flashes take no longer than 5-6 minutes. Screen black out went away too! BTW - I've been trying Blisspop from day one, along with DHackers CM12
Sent from my XT1254 using Tapatalk
Go to the full post
