[rom][5.0.2][lollipop][xt907]resurrection remix 5.3.4
Posted 18 February 2015 - 03:13 PM
- R1Lover, s.dubs, Joseberga and 3 others like this
So I can help you more
Posted 19 February 2015 - 08:09 PM
Unified Build available Moto_msm8960. Same download link
Posted 20 February 2015 - 10:02 PM
I am guessing KKBL?
Posted 21 February 2015 - 02:28 PM
Yeah KKBL
Posted 21 February 2015 - 05:13 PM
Great rom! However, cellular signal is lost after the second boot and google play services instantly crashes.
Posted 21 February 2015 - 07:24 PM
Is it lost? Working on deunified builds now. Wonder if that would change anything. Also maybe gapps issue? Did you use my link for gapps?
Posted 21 February 2015 - 09:47 PM
Been using the latest pa 5.0 gapps. It was stable with Blisspop.
Posted 22 February 2015 - 07:20 PM
I flash this rom with twrp custom recovery....after restart stuck on Resurrection Remix logo animation...i try many time...but stuck on logo..plz help me...my xt907 firmware is VZW_XT907_4.4.2-KDA20.62-15.1_1FF.xml...
Posted 22 February 2015 - 09:08 PM
work perfectly on mine.. Thx..
Posted 23 February 2015 - 12:43 AM
Posted 23 February 2015 - 04:32 AM
Here is my step :
1. Use TWRP instead of CWM
2. Go to the Advanced Wipe menu - Check Data - Change file system - Check EXT4 - Reboot Recovery (This Step WILL delete all your internal data!)
3. Do the normal wipes and install ROM Only - Reboot
4. After reboot then flash the GApps.
Posted 23 February 2015 - 07:26 AM
ok....i'll try this...
Posted 23 February 2015 - 08:25 AM
I'm uploading deunified build now for xt907. If you want to wait and try it.
Posted 23 February 2015 - 09:01 AM
Here is my step :
i try to install rom with your provided info...but stuck at rom logo...
Posted 24 February 2015 - 02:13 AM
a week ago i got same problem while installing BlissPop. I got these steps at BlissPop thread and success..
maybe you need to try this:
Reboot into recovery, click wipe, then format data and type yes. This will wipe internal SD and change the file format. Then reboot recovery and do the normal wipes for a clean install.
Posted 24 February 2015 - 07:33 AM
i do everything...but stuck at logo every time...almost all rom...
Posted 24 February 2015 - 10:14 AM
Crazy What device do you have?
Also what recovery are you using?
Posted 24 February 2015 - 08:53 PM
My device is XT907 and recovery is TWRP....and currently running official firmware...Rooted...
Posted 24 February 2015 - 10:00 PM
Also tagged with one or more of these keywords: Lollipop, Xt907, Motorola Razr M
