Droid Bionic stuck on motorola logo and I have no computer
Posted 17 February 2015 - 01:04 AM
Posted 17 February 2015 - 03:31 AM
Sent from my Nexus 6 using Tapatalk
Posted 17 February 2015 - 11:18 AM
Posted 17 February 2015 - 11:35 AM
EDIT:
That will not charge. But it will allow you to power up the phone via USB and flash the correct firmware. Once a successful flash is completed, the phone should charge on a normal USB.
Posted 08 March 2015 - 08:50 PM
- spainter likes this
Posted 08 March 2015 - 10:02 PM
Alright here's what I ended up doing. I cut the end of a USB cable to get the wires, I took the red and black wires and stripped some plastic off so I had just the wiring, I then took my battery out and in the spot the battery goes I put the red wiring on the positive side and the black wiring on the negative side, I had the wiring right in front of the little chips or whatever they're called, lol I apologize for being a bit of a noob, then I put the battery in so the wires would reach into the little slots of the battery itself where the chips are. So hoping this would work I plugged it up and let it set for about 3.5 hours. I then unhooked it and tried to start it up, of course only the boot menu but I was able to turn it on without a charger plugged in and ap fastboot was now saying battery OK! My nephew had a droid 3 that I seen was for a smaller battery but similar layout so I positioned my bionic battery so that it could fit into the slots and it popped on saying 70% battery! This made me happy, so I got access to a laptop, flashed it with the stock jelly bean firmware and here I am on my revived Bionic! What did I learn? NO FLASHING WITH A LOW BATTERY and do thorough research if you're new like me lol
Good job. The one thing nobody can take from you is what you have learned. Be it the hard way or other wise. To make things easier on yourself get a Black Hat adapter, You may never use it. But with the new phones coming out with out a removeable battery it will end up being the only way to get around this type of problem.
Posted 30 August 2016 - 12:12 AM
hello fulks sorry if i'm not posting my problem in the right place. i was given a droid bionic xt875 running cyanogenmod11 the i decided to upgrade to cm13 but while upgrading the phone fell off my hands and when off now its stuck on the moto logo. when i tried flashing with rsdlite it fails at 6/22 error cdt bin so now i dont know what to do please can somebody help me solve this problem? thanks very much in advance
