nitsuj17 UBK Rom
3 replies to this topic
#1 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 31 December 2012 - 05:22 PM
Presents
UltimateKangBang DNA
Current Downloads:
[HIDE]
[HIDE]
UKB_DNA_1.2.1.zip:
Mirror:
MD5sum: 578a5fecbfd1933c0b5883f490c54a47
Boot.img w/ init.d support:
MD5sum: c1ceea122f79302d1cb967c9062f1b3e
[/HIDE]
[/HIDE]
Sent from my HTC6435LVW using Tapatalk 2
#2 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 31 December 2012 - 05:23 PM
I will do my best to update the OP for the dev. He told me I could post it for him and handle the thread.
#3 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 31 December 2012 - 05:24 PM
UKB Highlights
Quote:
Initial Release!
Based on stock VZW 1.15.605.4 Release Software
Android 4.1.1 / Sense 4+
busybox 1.20
rooted with superuser
enabled custom recent apps actions in "display, gestures, buttons"
advanced power menu (reboot to recovery, hboot)
disabled package signature checking in services
rosie on screen menu added
removed ics/jb 3 dot legacy menu, and changed dimensions so its not blank space in apps
unhid several apps from rosie app drawer
removed persistent wifi notification in pulldown
volume keys can be used to zoom in/out in camera
fixed gallery dropbox force close
settings -> custom background in Messaging app *should* be fixed
long press back to kill app functionality
lyapota's musicbox v4
wifi scan interval set to 150 seconds from 15
added htc flashlight app
fastboot off by default
deleted useless "how to" videos from /system/media (47 mb)
default allow of non market app install
updated market apps
added titanium backup, genie widget, and google voice
people and app (quicklaunch) widget from j butterfly
friendstream widget (wip)
j butterfly wallpapers added to htc wallpaper picker
location icon removed from status bar
aroma options:
choose optional landscape enabled rosie
5x6 portrait and 8x4 landscape app drawer Rosie
remove apps (debloat)
option to dense (will install nova launcher)
choose statusbar layout w/o clock
choose statusbar layout w/ centered clock
wipe option (will NOT delete your internal data)
custom gps locations
install adblock hosts file
remove bootsound (will only work on data wipe)
choose verizon or stock htc boot ani
mod for mms screen on (when receiving new message screen will turn on)
accurate battery mod (100 images with percentages in them)
volume wake (will work with deep sleep)
remove usb debugging icon from status bar
optional jellybean blue battery icons
chooose between sense4+ recent apps or aosp multitasking
screen wake on sms/mms
desense options for sense or aosp apps
#4 papi92
papi92
    Developer
  • 727 posts
  • Twitter:afox2015
Posted 31 December 2012 - 05:25 PM
Changelog
Code:
1.2.1
12.21.12
fixed remove options for twitter, nfl mobile, htc car
remove option for htc dock (not functional)
add option to remove task manager GUI app
removed selection for verizon or gsm carrier (didnt fix mms settings for gsm)
fixed desense and launcher selections in aroma
-if you select sense you ll have a 2nd screen to select type of rosie launcher
-if you select desense you ll have a 2nd screen to select further customization
Sound enhancer shortcut added to Settings -> Sound (to enable beats)
1.2.0
12.20.12
added long press back to kill app functionality (lyapota)
long press home google now fixed w/ kill app mod, otherwise mod breaks it
lyapota's musicbox v4 ported to UKB
-adds soundenhancer fuctions to music player (not 100% yet)
new apm w/ hot reboot
