Please help me with network issues and other software issues.
Motorola XT 907
1 reply to this topic
#1 praveenkk
praveenkk
Posted 30 January 2015 - 06:30 AM
Hello Everyone,
This is my first post on this forum. I recently purchased Motorola XT 907 from ebay, unlocked version which is on 4.1.2 jellybean . For some reasons it is not connecting to EVDO data network, only to 1x, later i found out it my service provider don't provide support for evdo data on phones. So i changed network mode to 'EVDO' only from the test menu *#*#4636#*#* , but got no success. Then turned i off radio from test menu *#*#4636#*#* and started on it again, and it didn't worked for me again. So i changed network mode to the previous setting LTE/EVDO/CDMA/GSM. After all of that i inserted gsm SIM card and it is now cant search the network from manual network search. I tried to set all the network modes one by one. Plus now i have too many problems to handle:-
1. Cant see available networks on the network search list.
2. Cant update to the phone to kitkat by ota. It downloads the kitkat update but fails to install.
3. I tried to flash the jellybean stock ROM downloaded from
due to xml file errors by RSD lite it fails to install.
4. Due to flash failure every time i start the phone fastboot screen comes.
5. Cannot find the other stock ROMS on any site.
6. Cannot unlock the bootloader with motopocalypse.
7. GSM network is not working.
Please help me. I also did factory reset so many times, it didn't help.
#2 livinginkaos
Posted 30 January 2015 - 06:35 AM
Follow the directions in
thread. READ it all before starting.  Once that is done, you'll be on an unlockable version of KK.  Then go to
thread, and again, read it all first, then follow the instructions.
  • johnthehillbilly and praveenkk like this
