XT907 Problems
2 replies to this topic
#1 tedioustaco
tedioustaco
Posted 26 January 2015 - 12:33 PM
Hi, I have been browsing around different sites trying to fix my device with no avail.
Xt907, unlocked bootloader, stock 4.1.2 no root (I was running CM11, flashed stock back on worked fine).
Phone died overnight (was functioning properly before it died), got it 75% battery and tried to boot. Device now refuses to show anything but the M upon boot. I used Matt's Utility 1.20 when I flashed stock.
Battery is currently Low, I can get in/out of AP Fastboot but device will not charge even with going under BP Tools as suggested on XDA.
I'm afraid of damaging it beyond my knowledge so I am reverting to here.
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 26 January 2015 - 01:21 PM
Since your battery is dead, I wouldn't try anything until 1) you can get it to charge or 2) you can get a factory adapter
The battery won't charge in Fastboot, you need to power it off.  Hold the power button down for about 30 seconds and the phone should stay off.  Plug the phone into a WALL charger (not a computer) and let it charge overnight.  If it charges, then we can move forward.
#3 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 26 January 2015 - 02:32 PM
The factory adapter allows you to bypass the battery and power the phone and flash. It will not charge but once you get a successful flash it'll charge normally
Sent from my Nexus 6 using Tapatalk
sig by jayrod
The Rules-Follow them.
