dead Razr maxx hd
5 replies to this topic
#1 jokker1978
jokker1978
Posted 17 January 2015 - 07:05 PM
I managed to brick my phone messing with something I didn't know much about, trying downgrade from 4.4.2 back to 4.1.
I have tried the recover from the green robot factory reset now the phone is at please wait this may take a few minutes. so what do I need to do ?
#2 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 17 January 2015 - 07:14 PM
If you can get back to the bootloader you can try to flash the 4.4.2 version you had on the phone before you started.  The FXZ files and the tools you need are here on the forum, A quick search for the build should yeld the results you need.  Unless you are unlocked there isn't much else that can be done.  If you are not sure what build you were on I would start with 4.4.2.183.46.10 if that doesn't work then the .15 build is the last resort.  If you are unlocked there is more, but I would start with this:
  • jokker1978 likes this
#3 jokker1978
jokker1978
Posted 17 January 2015 - 08:12 PM
on the Ap fast boot screen it shows my phone to be locked. not sure what that means. I cant get it to take a flash using RDS
I get an unknown flashboot command
#4 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 17 January 2015 - 08:27 PM
Locked boot loader means you are not going to be able to flash anything but the stock fxz that is equal to or newer than the one you had before you tried to flash back to 4.1. You can't downgrade period.  so the only thing you can do is follow the instructions to the letter to first try to flash the .10 build.  If that works and you get a working phone don't take any ota's you can unlock the .10 build.  The .15 build, they fixed the exploit to unlock and root the phone, and there is nothing that can be done about that.  I don't believe there will be either.
#5 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 17 January 2015 - 08:35 PM
Read and don't get in a hurry, Set things up per instructions. Read again, And above all don't get in a hurry.  You don't want a paper weight instead of a phone.
#6 jokker1978
jokker1978
Posted 18 January 2015 - 02:55 PM
I had to use the .15 . I Reflased it and it started working . Thank you for your help.
  • spainter likes this
