plz help anyone
33 replies to this topic
#21 shahnawazkhan26
shahnawazkhan26
  • 20 posts
  • Locationsadiq Abad , Pakistan
  • Current Device(s):xt907
Posted 22 January 2015 - 04:59 AM
yes a popup msg appear .I check the box and hit OK . now I'm restarting my phone and PC. hope this work
:shootShah nawaz
#22 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 05:08 AM
not working. adb server out of date device offline.
:shootShah nawaz
#23 johnthehillbilly
Posted 22 January 2015 - 05:16 AM
Are you using a 2.0 USB port?
#24 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 05:23 AM
yes
:shootShah nawaz
#25 johnthehillbilly
Posted 22 January 2015 - 05:28 AM
In your command window.... Type ... adb kill-server... Hit enter
Then type adb devices ... Hit enter
#26 livinginkaos
Posted 22 January 2015 - 05:31 AM
Try going into developer options, click the revoke USB debugging authorizations, turn off then back on USB debugging and plug the device back in.
sent from my N6
  • johnthehillbilly likes this
#27 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 05:48 AM
daemon not runing starting it now on port 5037.daemon started successfuly .list of devices attached .TA59701MYV. offline
:shootShah nawaz
#28 johnthehillbilly
Posted 22 January 2015 - 05:52 AM
Now try what kaos suggested.....:)
#29 livinginkaos
Posted 22 January 2015 - 06:11 AM
Just to be sure, you did grab nprevette420's platform tools and are using them from that directory? And you've tried using a different USB port and allowing time for the adb drivers to install? The most common issues with a device offline are outdated tools, drivers, old authorizations or an emulator running of some sort like bluestacks or eclipse.
sent from my N6
  • johnthehillbilly and shahnawazkhan26 like this
#30 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 06:23 AM
I replace it with new adb and it works thanks.
nprevette420
And thanks all of you
  • johnthehillbilly and nprevette420 like this
:shootShah nawaz
#31 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 06:36 AM
:D
:shootShah nawaz
#32 rgunn77
rgunn77
Posted 15 February 2015 - 09:16 PM
I have the same issue. But my phone was unlocked and rooted. I got it used. It updated and now goes into reboot after 5 to 10 seconds after it boots up. I'm 4.1.2 jb can someone point me to the nearest. Rom don't want 4.4.2 kit kat.
#33 johnthehillbilly
Posted 15 February 2015 - 09:23 PM
Saying "it updated" tells us nothing..... What exactly did "it" update to..... And you say your phone was unlocked.... If it was unlocked, it will still be unlocked.....
What system version are you on currently (stock, not custom ROM) ......
#34 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 09 March 2015 - 09:16 PM
Please help friends .every apps in xt 907 has stopped . I think software is corrupt. Neither restore work nor rsd lite with full flash .software is flash sucessfuly but no clean software is installed.plz help me
:shootShah nawaz
