plz help anyone
33 replies to this topic
#1 shahnawazkhan26
shahnawazkhan26
  • 20 posts
  • Locationsadiq Abad , Pakistan
  • Current Device(s):xt907
Posted 11 January 2015 - 06:34 AM
recently i bought droid razr xt907      98.18.94    v4.1.2
today i  root the droid and root is successful everything was working but when i install cwm      recovery-clockwork-6.0.4.4-xt907.img
with recovery tool and restart the device into recovery  but i saw some options   device is locked, status code: 0
failed to hab check for recovery:0x56
fastboot reason:boot failure
i press the power button and mobile start normaly but i cant reset factory setting . when device is restart same options are appear.
then unfortunately i  update the system software. when the update completely download i install it. now my mobile is starting but two are five seconds mobile automaticaly shut down and go into the recovery option. every time mobile is restarting and shuting down.
i think cwm is not working with lock bootloader .plz help me in this situation what to do. any tool to flash xt907 .
sorry im weak in english
:shootShah nawaz
#2 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 11 January 2015 - 07:17 AM
You have to unlock the device before you can install a custom recovery.  Search under your phones threads for information about unlocking it.
  • johnthehillbilly likes this
#3 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 11 January 2015 - 09:43 AM
If you updated, you might not be able to unlock anymore. Go here to flash the latest FW to get the phone working again:
Sent from my HTC6525LVW using Tapatalk
  • johnthehillbilly and shahnawazkhan26 like this
#4 johnthehillbilly
Posted 11 January 2015 - 12:23 PM
If you did NOT update already..... Try this one
[FXZ]-4.4.2-183.46.10#entry433488
If that flashes OK for you .... Then you should be able to unlock .... Then you can install CWM or TWRP recovery... Whichever you choose....:)
  • RikRong and shahnawazkhan26 like this
#5 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 11 January 2015 - 06:20 PM
thanks
thanks im try to flash the phone.  any other tool or FW plz suggest me .
:shootShah nawaz
#6 johnthehillbilly
Posted 11 January 2015 - 06:24 PM
If you follow the link I posted..... All the info .... Everything you need is there...:):)
#7 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 11 January 2015 - 06:25 PM
If that flashes OK for you .... Then you should be able to unlock .... Then you can install CWM or TWRP recovery... Whichever you choose.... :)
thanks  no i did not update already.
:shootShah nawaz
#8 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 11 January 2015 - 06:27 PM
If you follow the link I posted..... All the info .... Everything you need is there... :) :)
 thanks i follow the post
:shootShah nawaz
#9 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 12 January 2015 - 12:22 AM
thanksss finaly my phone is working hurrah
  • johnthehillbilly, LDubs and RikRong like this
:shootShah nawaz
#10 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 18 January 2015 - 03:50 AM
hi
anyone know what is the problem with debugging. mobile go software not recognise my device.after flashing the phone with 4.4.2 .plz
:shootShah nawaz
#11 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 21 January 2015 - 02:38 PM
hi
You may have an older version of fastboot files. Try these
Need Help? Send me a message
#12 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 03:50 AM
Hi .plz tell me how to use these files. Thanks
:shootShah nawaz
#13 johnthehillbilly
Posted 22 January 2015 - 04:00 AM
Those fastboot files are only to replace any older existing ones you may have......im not sure thats what your issue is.....
You asked about debugging..... Have you enabled USB debugging (in developer options) on your phone
  • shahnawazkhan26 likes this
#14 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 04:13 AM
yes I enable debugging . mobile go software scanning the device but a error appear. oops your device is sleeping now .please reconnect the USB cable to wake it up.
:shootShah nawaz
#15 johnthehillbilly
Posted 22 January 2015 - 04:21 AM
In developer options, make sure the stay awake box is checked... See if that helps
#16 johnthehillbilly
Posted 22 January 2015 - 04:23 AM
If that does not work.... Try a newer version of MobileGo software.....
#17 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 04:26 AM
ok
:shootShah nawaz
#18 shahnawazkhan26
shahnawazkhan26
  • 20 posts
Posted 22 January 2015 - 04:43 AM
I install minimal adb fastboot v.1.1.3. when I type. adb devices. it shows.
adb server is out of date . killing ...
list of devices attached
TA59701MYV. offline
what is this?
:shootShah nawaz
#19 johnthehillbilly
Posted 22 January 2015 - 04:50 AM
With the phone plugged in to PC go into developer options and turn off USB debugging.... Wait a second then turn it back on..... You should get a popup on your phone with the rsa fingerprint asking if you want to allow the phone..... Check the box that says "always allow" then hit allow/ok .....
#20 johnthehillbilly
Posted 22 January 2015 - 04:51 AM
Reboot both phone and PC
