[ROM][5.0.2][AOSP] AOD-CuStOm (Updated 04-13-15)
5.0.2 AOSP New xt926 xt925 xt907 Layers
148 replies to this topic
#1 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 10 January 2015 - 03:54 PM
This my Friends is a sign of a change.
To those that have the ability to change
Will reap the benefits from this change.
This is Basically Out Of the Box AOSP.
Nothing Blissfull or Dirty about this.
Just Simply Simple
With the Basic features to get you though the day.
Special Thanks
In no Particular Order
- Google
- dhacker29
- TheRingMaster
- BitSyko Development (for Layers)
- nitroglycerine33
- papi92
- Mazda
- Testers (Since I don't have a working SIMs reader)
- Many others... (if you're feeling upset being out of the thanks list just send a PM )
Standard Disclaimer
Your warranty is now void.
I am not responsible for bricked devices, dead SD cards,
thermonuclear war, or you getting fired because the alarm app failed. Please
do some research if you have any concerns about features included in this ROM
before flashing it! YOU are choosing to make these modifications, and if
you point the finger at me for messing up your device, I will laugh at you
Installation Instructions....
- Must be running KKBL (Don't expect JBBL anytime Soon)
- Make sure you're running a proper working Recovery (CWM or TWRP)
  (TWRP 2.8.0.1 or Newer Preferred)
- Copy 5.0.x GApps and ROM zip to your internal or external Storage
- Boot into Recovery and Backup what ya got.
- Suggest formating System, Data, Cache (Do Not FORMAT Internal Storage)
- Flash ROM zip
- Flash GApps zip
- Reboot
Changelog
-- Fixed Clear Recents from Crashing
-- Fixed Battery Notification Switch (You can turn it Off and On Now)
-- Added Option to disable Google search in Recent Task menu (Option is in Development Settings for now)
-- A few more Bugs Squashed..
Changelog
-- Re worked entire theme (Prep for Layers addons)
-- QS Tile adjustment
-- Viper Audio (Included in the build)
-- Adaway app
-- Layers Manager (Included in the build)
-- Extra Govs and Schedulars (Thanks to
-- Kernel Adiutor (A nice Choice for kernel adjustments)
-- Nova Launcher is Default Launcher
-- Moto Turbo CommandCenter Widget (Watchout its Huge)
-- Some additional Memory leak fixes...
-- Fix Notificaiton light switch and set default color
-- Flash and find the rest.....  :p
Changelog
-- Added Dark Material for a Darker experience.
-- Fixed init.d scripts not loading on reboot
-- Fixed some minor Bluetooth issues..
-- Added ability to tap on Statusbar Time to open Clock
-- Added ability to tap on Statusbar Date to open Calendar
-- Adjusted some internal device specific configs.
-- Speed things up a bit (Thanks Team DU..)
-- Added Double-Tap-Statusbar to sleep Option in Display Settings (On By Default)
-- Added Close all Recents
-- Kill app Longpress Back on Nav. (Optional in Developer Settings)
-- Minor updates to performance and Battery like..
Changelog
-- Added in 1% Battery avaiblility
-- Added in Volume key Music Skip (Turned on by Default)
-- Added in Gesture Status bar brightness control
-- Added in Center Clock Mod and Color
-- Added in Notification and Battery Light Mod
-- Added in Device Profiles
-- Added in Ambient display (You can disable it in Display Settings)
-- Added fix for Status bar location icon always on...
-- Optimized for speed
-- Added Super Su into the rom updater
-- Some additional pre-theme adjustment.
-- Undercover work (To many other changes to list. HAHAHAHA.)
What Works....
Everything so far
NFC has issues, but trying to weed it out.
        >>>>>Caution<<<<<
Due to the Device tree changes. Unified builds have been Terminated.
Please choose your device from the list below.
I am only able to test and boot a xt926 device, but don't have a problem
making ROMs available for other Popular devices.
The Goods..  :D
Suggested Updated 5.0.x GApps  :D
Recoveries  :D
xt926=     >>>>>
xt925=     >>>>>
xt907=     >>>>>
SuperSu
Included in the ROM Zip
I don't normally ask for Donations and I will not start now, but if you feel the need then it will be greatly appreciated
  • Bama, livinginkaos, cmh714 and 6 others like this
#2 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 10 January 2015 - 03:55 PM
Previous Unified Build
The Goods..
#3 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Mine
#4 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Mine tooo
#5 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 11 January 2015 - 12:39 PM
Not yours :p
Sent from my Nexus 6 using Tapatalk
  • nobe1976 likes this
sig by jayrod
The Rules-Follow them.
#6 xKroniK13x
xKroniK13x
  • 284 posts
  • LocationAtlanta, GA
  • Current Device(s):Moto X 2014 Pure Edition || Motorola DROID RAZR M || Archos G9 101 || Microsoft Surface Pro 2 || Chromecast
Posted 12 January 2015 - 10:23 AM
I used a Android Open Development 5.0 for a while that was originally released on dhacker's twitter. Nice to see it's still being developed. Thanks for the share!
Moto X 2014 Pure Edition Unlocked on Pure Rooted 5.1
#7 hectorlumbago
hectorlumbago
  • 77 posts
  • Twitter:hectorlumbago
  • Google+:hectorlumbago
Posted 12 January 2015 - 04:54 PM
Installed this pm and kept it simple, only what we use.  Looks good so far Nobe:-)
#8 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 13 January 2015 - 01:19 PM
HI Nobe, it has been a while since you and I crossed pathes.  I've tried some Lollipop ROMS and have been getting my butt  kicked.  Not sure why.  I tried this one, along with following directions clearly as stated, and guess what - it seems to work!
It seemed snappy so the first program I loaded just for grins was Quadrant.  I know many don't like it or use it, but is all I've used so I can make comparisons.  THIS ROM scored over 5900 first shot. That is the highest score I've ever had by over 500 points.  Wow.
So, off the kick of scores - plan to set this up and run for a few days.  Happy to test / try stuff if you'd like.  I have yet to find a way to kill this beast so willing to try anything just about.
Sir, I thank you for your work on our phones!
Proud father of a US Marine
#9 mrf582
mrf582
  • 44 posts
Posted 14 January 2015 - 09:20 AM
Any loss of data connection upon reboot like CM12 based ROMs? If not, why not?
#10 hectorlumbago
hectorlumbago
  • 77 posts
Posted 14 January 2015 - 10:56 AM
connection occasionally disappears, but only for short time for me
#11 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 16 January 2015 - 04:58 AM
So, I have had zero bluetooth success.  Connects just fine, quick and no problem to car.  Call comes in and goes to the phone, not the car.  When call over, I cannot hang up and the phone freezes.  Restarting phone disconnects the phone and I have to start over.
Things to try?
Question also, is there a LP build for this device that does have BT working fine that anyone knows of?  BT if pretty big on my list of needs.
#12 Zeljko1234
Zeljko1234
  • 94 posts
  • Current Device(s):Droid Razr Maxx HD, Atrix 4G, Nexus 7, LG G Pad 8.3
Posted 16 January 2015 - 05:07 AM
I have the same or similar problem with BT. One user posted that BT works without gapps. I haven't tried yet but if you have time, you can try and please let us know.
#13 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 16 January 2015 - 05:15 AM
LOL, without GAPPS sort of like choosing between losing a hand or a foot!   Just kidding of course.   I switch back and forth between two ROMs often before calling the newer one a daily driver, so I'll reload this and give it a shot in a bit.
Thanks for the idea - maybe it will help with the fix if it works.
#14 Zeljko1234
Zeljko1234
  • 94 posts
Posted 16 January 2015 - 06:37 AM
If you're switching roms often then you're perfect one to test. Would be really crazy if gapps brakes BT but I wouldn't surprise a lot.
#15 motogun
motogun
  • 9 posts
  • Current Device(s):xt926
Posted 16 January 2015 - 10:41 AM
how about network missing bugs..
#16 j37hr0
j37hr0
  • 13 posts
Posted 17 January 2015 - 10:23 AM
Same problem with bluetooth. I dug out my LGS-250 headset to test. Music plays great through it, but the call functionality is missing.
Am I just dumb? I can't figure out how to switch to the Dark Material you mentioned.
#17 xubeiga
xubeiga
  • 17 posts
Posted 27 January 2015 - 07:04 AM
is anyone using this Rom for some time?
how is battery life?
i heard that batt life in these LP roms are very bad compared to KK roms.
EDITED OR I'D GET SUED
#18 j37hr0
j37hr0
  • 13 posts
Posted 27 January 2015 - 09:17 AM
i'd like to try this one. Nobe is my god and i love him <3 we'll marry soon. wait for the invites
I've been using this as a daily for 2 weeks. Not a very heavy user. Also on T-Mobile so no LTE, never use WiFi always use HSPDA+,
  • xubeiga likes this
#19 jl90
jl90
    \m/
  • 1,642 posts
  • LocationPhoenix, Az.
Posted 27 January 2015 - 11:27 AM
Nobe...dude...LOL!  :sneaky :blink :ohmy :mellow2
#20 johnthehillbilly
Posted 27 January 2015 - 11:33 AM
Um
  • nobe1976, jl90 and xKroniK13x like this
Also tagged with one or more of these keywords: 5.0.2, AOSP, New, xt926, xt925, xt907, Layers
