CM12 - Official - Nightly - XT926 or msm_8960?
19 replies to this topic
#1 mrf582
mrf582
  • 44 posts
Posted 07 January 2015 - 11:17 AM
This is NOT for those on the JBBL.
This is ONLY for those on the KBBL.
DOWNLOAD (msm_8960) -
CHANGELOG (msm_8960) -
Development ended on 1/14/2015
Anyone given this a shot?
1/18/2015 - Looks like they un-unified it.
RECOVERY -
DOWNLOAD (XT926) -
GAPPS -
CHANGELOG (XT926) -
#2 Playb3yond
Playb3yond
  • 75 posts
Posted 07 January 2015 - 02:04 PM
So far so good, no force closes. No bugs that I have seen. I'm pleased with it
#3 mrf582
mrf582
  • 44 posts
Posted 08 January 2015 - 06:33 AM
Cool. Have you been able to test the following 'core' functions?
- Data (some people using ROMs that use a modified CM12 official release are reporting that during some reboots, data doesn't work and they have to reboot again)
- Bluetooth (audio and phone)
- Camera
- SD Card
- WiFi
- MMS (both on cellular and WiFi)
- Youtube
- Netflix
- Chromecast
#4 Playb3yond
Playb3yond
  • 75 posts
Posted 08 January 2015 - 07:04 AM
I've tested all but chromecast, MMS (only tested on WiFi) & Netflix and everything seems to work fine, the first nightly, YouTube wasn't working but in the 2nd its fixed. I don't have a chromecast at the moment but when I do get around one. I'll be sure to test it. Bluetooth was only tested with a beatspill. WiFi works like a charm. SD card is faster than usual. The front facing has low light issues
#5 Playb3yond
Playb3yond
  • 75 posts
Posted 08 January 2015 - 07:09 AM
For the data reboot issue, I disabled NFC and had no problems. I'm on Net10 (T-Mobile), though at first it wasn't working for me either, but that bug seems to be squashed. Can't tell because I mostly use WiFi to conserve my data
#6 mrf582
mrf582
  • 44 posts
Posted 09 January 2015 - 09:45 AM
Interesting info about disabling NFC. I wonder if this info has been fed back to the CM12 team.
#7 mrf582
mrf582
  • 44 posts
Posted 09 January 2015 - 03:06 PM
So NFC has no effect on mine. It's disabled by default and I didn't have to turn it off. There doesn't seem to be a rhyme or reason to when data won't come up after a reboot.
#8 Capt14k
Capt14k
  • 37 posts
Posted 13 January 2015 - 07:04 AM
Nightly won't boot starting with 01/12 release.  Install then reboot gets stuck on Motorola screen
  • mrf582 likes this
#9 diarrik
diarrik
  • Current Device(s):motorola droid razr m
Posted 13 January 2015 - 10:13 AM
same problem here even 01/13 doing the same thing.
  • mrf582 likes this
#10 FareakyGeek
FareakyGeek
  • 29 posts
Posted 13 January 2015 - 01:02 PM
Same here with 01.13, won't boot and stuck at bootloader warning!
  • mrf582 likes this
#11 dvgb131
dvgb131
  • 156 posts
  • Twitter:dvgb173
  • LocationAlbany
Posted 13 January 2015 - 01:11 PM
Interesting. DHacker said on twitter not to use 1/12 or 1/13 builds. Wait for 1/14.
  • mrf582 likes this
Doug B.
#12 mrf582
mrf582
  • 44 posts
Posted 14 January 2015 - 09:21 AM
Thanks for the heads up guys. i was actually considering updating from my 1/9 release.
#13 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 16 January 2015 - 07:08 AM
Tried the 1/15 nightly and could not get past boot.  Tried a few times......... bummer.
TWRP 2.8.3.x, wiped everything.
Thoughts?
Proud father of a US Marine
#14 jad1514
jad1514
Posted 17 January 2015 - 12:31 AM
1/15 not work. Install with error (sorry for my english)
#15 Capt14k
Capt14k
  • 37 posts
Posted 17 January 2015 - 06:15 AM
1/15 doesn't get past init.  Looks like we need to install a new recovery according to
dhacker29
#16 mrf582
mrf582
  • 44 posts
Posted 18 January 2015 - 02:10 AM
I used this. TWRP v2.8.4 -
Then I was able to flash the msm_8960 1/14 nightly from the 'CM Updates' menu.
I also tried the non-unified XT926 1/15 build but it just sat there spinning at the CM boot logo for longer than my patience allowed.
#17 ranland
ranland
Posted 20 January 2015 - 06:45 PM
Can I use this ROM for XT926M model?
Dumb question maybe?
#18 blindman
blindman
  • 45 posts
Posted 22 January 2015 - 06:27 PM
I am on CM11 and under the updates I see cm12 nightly 1/14. Can I just update through cm11 or do I have to flash with new gaps?
Also I've had a problem connecting to my VPN when on Verizons LTE since updating to 4.4. Does anybody know if Cm 12 would work with the VPN?
#19 dvgb131
dvgb131
  • 156 posts
  • Twitter:dvgb173
  • LocationAlbany
Posted 23 January 2015 - 05:00 AM
You need new LP gapps.
Sorry, I don't use VPN.
Doug B.
Doug B.
#20 mrf582
mrf582
  • 44 posts
Posted 23 January 2015 - 08:41 PM
Anyone able to flash the latest nightlies and have it boot?
The latest that works for me is the 1/14 release.
So I did a clean install by typing in 'yes' for a full data wipe and was able to boot the 1/23 Nightly. Though, I forgot to install GApps so I went back into recovery and did so. Seems to be working fine. Haven't yet had a chance to test everything but at least it boots!
