Need help in updating...
12 replies to this topic
#1 cmh714
Posted 31 December 2014 - 12:39 PM
New NX6 came in with LNX07M, and immediately wanted to update to 5.0.1 but I held off. I unlocked first and then was able to load up root.
Went to take the OTA and it failed during install but now says I am up to date but still on 5.0 LNX07M.
Then figured I would flash via fastboot but getting errors that way too when its trying to flash the image zip file. see below
sending 'bootloader' (3807 KB)...
OKAY [  0.124s]
writing 'bootloader'...
(bootloader) flashing partition ...
(bootloader) This may take a few seconds if a
(bootloader) different partition table is being
(bootloader) flashed since we need to backup
(bootloader) and restore a few partitions
(bootloader) Flashing primary GPT image...
(bootloader) Flashing backup GPT image...
(bootloader) flashing aboot ...
(bootloader) flashing sbl1 ...
(bootloader) flashing rpm ...
(bootloader) flashing tz ...
(bootloader) flashing sdi ...
(bootloader) flashing logo ...
OKAY [  0.573s]
finished. total time: 0.697s
rebooting into bootloader...
OKAY [  0.001s]
finished. total time: 0.001s
sending 'radio' (67169 KB)...
OKAY [  2.119s]
writing 'radio'...
(bootloader) flashing modem ...
(bootloader) flashing mdm1m9kefs1 ...
(bootloader) flashing mdm1m9kefs2 ...
(bootloader) flashing mdm1m9kefs3 ...
(bootloader) flashing versions ...
OKAY [  0.980s]
finished. total time: 3.099s
OKAY [  0.001s]
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
fastboot(54168,0xa090a1d4) malloc: *** mach_vm_map(size=1681293312) failed (error code=3)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
failed to allocate 1679613116 bytes
error: update package missing system.img
system.img does exist in the zip and is 1.68GB so not sure whats up.....
TIA
#2 cmh714
Posted 31 December 2014 - 12:43 PM
hmm, I believe I am using an old fastboot.exe so getting new files....
#3 cmh714
Posted 31 December 2014 - 12:59 PM
OK, I am struggling....help appreciated as always :)
#4 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
  • Google+:amcsocold@gmail.com
Posted 31 December 2014 - 01:06 PM
Ota will fail. The script is broken. Follow Sam's noob guide.
Sent from my Nexus 6 using Tapatalk
sig by jayrod
The Rules-Follow them.
#5 soocold
soocold
    OC & OCD Specialist
  • 8,736 posts
For what it's worth I'm still on the 5.0
sig by jayrod
#6 cmh714
Posted 31 December 2014 - 01:17 PM
Thanks but thats no help :):):)
I am following Sams guide...a little frustrating...
#7 livinginkaos
Posted 31 December 2014 - 01:19 PM
HoN is almost ready.....
I just modified the script.  Unzipped everything into the same folder.  Put my platform tools in there as well and ran it.  Along with twrp in there only to boot from, leaving stock recovery on.
http://www.drdevs.co...nexus-flash.bat
#8 cmh714
Posted 31 December 2014 - 02:08 PM
I will check that out Kaos, but I was able to get myself updated.....I had to run each command by hand but that worked for some reason....
EDIT: Since it says bat file it aint for a Mac ;) but I will take a look
#9 livinginkaos
Posted 31 December 2014 - 02:58 PM
Right, I just figured you could see what I did and make something work for you.  Doing them individually works just as well.
  • cmh714 likes this
#10 SamuriHL
  • 44,378 posts
Posted 31 December 2014 - 07:20 PM
I haven't added Mac/Linux support for House of Nexus yet.  It'll come eventually but not tonight.  But you can look at the generated bat file and convert it to an SH script if you're comfortable with that sort of thing.  It'll at least setup the factory image in a way that can easily flash via fastboot.
#11 SamuriHL
  • 44,378 posts
Posted 01 January 2015 - 08:27 AM
Mac/Linux support is incoming momentarily.  You up for trying it?
  • johnlgalt likes this
#12 cmh714
Posted 01 January 2015 - 08:51 AM
Sure I can take a look see for ya :)
#13 SamuriHL
  • 44,378 posts
Posted 01 January 2015 - 09:24 AM
It should maybe in theory possibly work.  :D  I tested echo'ing out all the commands under cygwin so as long as fastboot is setup for you, it should flash properly.
