Recovery Contact Phone
Posted 29 January 2012 - 04:38 PM
Thanks!
Posted 29 January 2012 - 04:55 PM
If you tell us what Rom I can help you. There are .apk and odex replacement files for all Odex Roms (non-De-odxed ones) in our CDMA Development section and/or App section (they have been kind of moved around). If you are using a 6.11.748 use those .apk and.odex, if you are using 6.12.173, use those.I deleted accidentally the apk contact from my phone. I installed the "go contacts ex" and make calls and answer, but this does not record calls, is not history. Does anyone know how I could recover it without having to do a new installation of the rom.
Thanks!
If you are on a De-Odexed Rom then I cannot help you, you are gonna either have to extract it from the zip and put the .apk back from the /system/app/ folder, or reinstall the Rom.
Posted 30 January 2012 - 02:17 AM
my version system is 651.73.1083
Number version: 6.5.1_73_SLC-83M
Posted 30 January 2012 - 02:20 AM
Seeing as that is not a CDMA XT912, I do not have the files to replace your APK. You can either take it from your downloaded Rom or reinstall it. Your callThanks,
Posted 30 January 2012 - 03:28 AM
My version is Brazil. .BR
Thanks.
