I think I bricked after updating to JB...
Posted 25 December 2012 - 02:02 AM
Posted 25 December 2012 - 02:27 AM
If you are absolutely sure you are bricked and cannot boot up, you can try this but understand, you take responsibility if it does not work and you may have to wait for a dev to create something or for fastboot files to show up.
Repeat, this worked when I bricked on ICS before there was a fastboot file and we could not roll back to GB.
If you use the razr utility to flash the 211 (ICS) fastboot files, you will likely run into a few errors but most of it should flash. Your phone will essentially be a mix of ICS and JB and will not boot up. Go into recovery and flash the update zip for JB. As long as the file that is causing the failure now (/system/app/backupassistanceclient.apk), is restored, the update should (maybe) go through.
Posted 25 December 2012 - 07:04 AM
A lot of people in the original thread ran through it this way to get to something working. The only issue with this is that you will not have root and there's no known root method right now.
Posted 25 December 2012 - 06:07 PM
Posted 25 December 2012 - 06:12 PM
What I would do in your position.
Fastboot back to .211
clear cache
load up the JB update through moto restore
Pray someone finds a root method soon.
Edit: This should get you a working phone WITHOUT ROOT. There is no known root method for this new build as of my knowledge right now.
Posted 26 December 2012 - 05:31 PM
You can also try Fastbooting back to ICS using DroidRazrUtility 1.82 and then reapply the update. Although you cannot flash back to a running ICS, you can confuse the updater enough with the files being present to start the entire process over again.
Uuhhh....this is exactly what I said to do. You started out with, "can also try" but then just repeated my advice. Lol
Posted 29 December 2012 - 03:13 AM
Posted 29 December 2012 - 12:09 PM
Posted 29 December 2012 - 12:16 PM
Also tagged with one or more of these keywords: recovery, upgrade, jelly bean, help, brick
DroidRzr.com →
New Member Introductions and Site Assistance →
moto razr xt912Started by Dragonfireboz69 , 04 Jan 2017 help |
DroidRzr.com →
Xoom2me mz607 screen freeze after reset, recovery , flashing firmwareStarted by raoeneu , 15 Feb 2016 screen freeze, reset, recovery and 1 more... |
Android General →
General Device Support →
RAZR MAXX XT910 Lolipop install failedStarted by locke , 11 Dec 2015 recovery, reset, restore to stock |
DroidRzr.com →
droid razr xt925Started by dunamiszygote , 17 Nov 2015 help |
Answered
Android General →
RAZR XT912 ID is Nexus 7 on PC and no stock recoveryStarted by Manetek , 18 Oct 2015 RAZR, xt912, bricked, recovery and 1 more... |
