1212 replies to this topic
#161 Brian
Brian
    Everyday holds a different challenge, how will you meet them?
  • 181 posts
  • LocationAnywhere you Aren't
Posted 24 December 2012 - 03:54 PM
I guess that is a no to marriage...lol :P
#162 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Pros:
Fast
Relatively little bloatware to stock I'VE
Cooler looking
Very AOSP
Cons:
Data and Wifi reception is weaker
Don't know what getting on this leak entails...
This kernel seems to use more memory
Have to retweak everything lol
  • Olao99 likes this
#163 Narffran
Narffran
  • 147 posts
  • Twitter:Fran_Granfield
  • LocationNorth of Boston MA
Posted 24 December 2012 - 03:55 PM
5 minutes of playing with it and I will say it's fast. I however don't see the circle widgets. Might pull them from my HD MAXX and see what happens. For my wife to say it's fast that in it's self is saying a lot.
#164 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 24 December 2012 - 03:56 PM
A little too complicated sorry lol
#165 Pugz
Pugz
  • 7 posts
Posted 24 December 2012 - 03:57 PM
I just tried installing it through recovery and it gives me an error saying "signature verification failed" Installation aborted.
weird.
#166 jacogs
jacogs
Posted 24 December 2012 - 03:58 PM
Use this:
This is not official OTA, it's a build test build that got pushed to the wrong server.
Thanks, I used the utility and now im back to 100% stock, preesh! But now, my update checker says my phone is up to date. Did they pull the update since it was a mistake XD? If thats the case, at least my phone will be ready to go in 2013 for the official update.
#167 Cirrus
Cirrus
  • Current Device(s):Razr Maxx
Posted 24 December 2012 - 03:59 PM
Same size in Bytes, just using different calculation for Bytes to megabytes. 1000 vs 1024.
Matt,
Got it, thanks!
#168 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
They pulled it, have to grab from the OP. We got mirrors.
#169 ilanderech
ilanderech
    I want to be blue!!!
  • 34 posts
  • Google+:ilanderech@gmail.com
  • LocationMexico City
  • Current Device(s):OG Razr, Razr Maxx
Posted 24 December 2012 - 04:03 PM
Im having the same issue Brian is I cant update binary on SU
#170 sciaid
sciaid
  • 7 posts
  • LocationSan Diego
Posted 24 December 2012 - 04:04 PM
sorry for the noob question but does not being fastbootable to ICS mean that we are stuck on this if we apply this?
#171 darkcomartist
darkcomartist
  • 12 posts
Posted 24 December 2012 - 04:08 PM
I'm trying to install from droid recovery but it keeps aborting. Anyone have any ideas what I might be doing wrong? I updated the name from "blur*****" to "update.zip", put in the external sd card and from droid recovery i'm trying to install update from external sd card but it's aborted 4 times already. I've stopped and tried to do it again from scratch but nothing. Any help will be appreciated.
#172 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 24 December 2012 - 04:09 PM
Yup.
  • sciaid likes this
#173 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 24 December 2012 - 04:10 PM
Update anyway I guess? I know people are having the issue and I don't know why. Others said it worked fine.
/confused
#174 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
  • Current Device(s):Nexus 5
Posted 24 December 2012 - 04:11 PM
Can't help unless you tell me exactly word for word what the failure is. But first, I would try wiping cache in recovery just before you apply the update. If it still fails, chances are you need to use Matt's utility to fastboot back to stock 211. Then root with his utility, update su binaries, protect root with OTA rootkeeper, then reboot into recovery, wipe cache, and try applying the update again.
Edit: And you must you stock motorola recovery.
#175 Brian
Brian
  • 181 posts
Posted 24 December 2012 - 04:13 PM
any suggestions?
#176 jtelander
jtelander
  • 134 posts
Posted 24 December 2012 - 04:16 PM
This problem resolved for me when I opened SU in Play Store and chcked the box "outdated binary notification"
I was then given an option update the binary
#177 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
Posted 24 December 2012 - 04:21 PM
I can confirm sideloading works. FYI, always wipe cache in recovery just prior to applying the update in recovery.
#178 loonie01
loonie01
  • 190 posts
Posted 24 December 2012 - 04:22 PM
Installed nicely on OG razr. Feels a little smoother. Unfortunately I've gone to the GS3 but visually it'snice
#179 darkcomartist
darkcomartist
  • 12 posts
I wiped cache as you suggested but to no avail. I'm also running .211. Here's the error message it gave me
"Verifying current system...
assert failed: apply_patch_check("/system/bin/logwrapp
er", "f39fcbd278b9e92e9fbedc6a62a047dc23459416", "4a63
fec78956def045b442910a754fa640db8f5a")
e:error in /tmp/sideload/package.zip
(status 7)
Instalation aborted."
#180 Dennelly
Dennelly
  • 25 posts
Posted 24 December 2012 - 04:24 PM
My phone is dead and I might hold off until tomorrow since my moms razr which is stock hasn't got the OTA either.
