I was able to save the $2.99, and edit the file using and .FoxFi does NOT work.Spend the $2.99 and buy SQLite Editor and use the hotspot hack.
#1161
Posted 10 January 2013 - 12:42 PM
#1162
Posted 10 January 2013 - 02:43 PM
I have triple checked all of my location settings, everything is allowed. I can't figure out what's wrong.
Is there a way to flash just a radio fix, if I somehow corrupted my download of the update leak?
#1163
Posted 10 January 2013 - 03:27 PM
#1164
Posted 10 January 2013 - 03:36 PM
If you are rooted and on Jellybean... you should enjoy it lolDumb question: If root was restored just within the voodoo OTA app, do we still have to do the steps in post 2?
#1165
Posted 10 January 2013 - 03:41 PM
So... that's a no?
#1166
Posted 10 January 2013 - 04:51 PM
Has anyone else had issues with GPS refusing to lock? I've tried doing navigation through both GMaps Navigation and Waze, on straight, fresh JB stock and a couple other roms, but no luck. I just get an endless "Searching for GPS..." Both apps will find my general location through WiFi, but won't lock GPS at all. I even tried using the GPS fix utilities and nothing's worked.
This happened to me when I had my Droid X. I went crazy trying to fix it. Flashing roms and then back to stock a bunch of times, every app I could find that was supposed to fix it. Nothing worked.
Called VZW, was still within my one year warranty, so they sent me a new one no charge.
#1167 Guest_Syncteesy_*
Posted 15 January 2013 - 05:21 AM
Edited by Thach, 15 January 2013 - 05:29 AM.
Spamming topic. Reworded post to reflect what I would hope this person is thinking.
- dawg72 likes this
#1168
Posted 16 January 2013 - 11:58 AM
Here is the thread:
#1169
Posted 16 January 2013 - 12:32 PM
#1170
Posted 16 January 2013 - 01:17 PM
#1171
Posted 16 January 2013 - 07:41 PM
#1172
Posted 16 January 2013 - 08:41 PM
makes me just as sad as no ICE on my RAZR MAXX HD
#1173
Posted 16 January 2013 - 10:08 PM
This is the file I got when downloading from Matt's link and a few others. When I install from recovery, it always takes me to .215, not JB. Am I missing something?
After the first time I flashed back to .211 via Matt's utility, rooted, did setup, and got same result.
Then I flashed back to .211 again, did setup, and got same result.
I'm kind of unsure what I missed.
#1174
Posted 16 January 2013 - 10:10 PM
no Circles though
Circles widget is not a stock item in jelly bean. It is stock item for some devices running jelly bean. The easiest way to get circles is use the razr m launcher which had the circles widget. Unfortunately the widget can't be used on a third party launcher as of yet, so you have to use the razr m launcher to use the circles widget.
Sent from my XT912 using TapaFUZION 1.0
#1175
Posted 16 January 2013 - 10:26 PM
Blur_Version.6.16.211.XT912.Verizon.en.US.zip
Can you give me a link you downloaded from. Looks like you might have grabbed the 215 ICS instead.
#1176
Posted 17 January 2013 - 02:26 AM
I got one from his mydroidfiles and the following listed link on the first page of this thread.
#1177
Posted 17 January 2013 - 03:15 AM
Indeed it does. I got one from Matt's OP here:
When you run it through stock recovery does anything fail?
#1178
Posted 17 January 2013 - 03:36 AM
is there a guide to doing this? I am currently all stock, no 3rd party.Circles widget is not a stock item in jelly bean. It is stock item for some devices running jelly bean. The easiest way to get circles is use the razr m launcher which had the circles widget. Unfortunately the widget can't be used on a third party launcher as of yet, so you have to use the razr m launcher to use the circles widget.
#1179
Posted 17 January 2013 - 05:51 AM
What's the difference between:
And...
XT912-98.72.8-SystemPull.zip
If needed, I can post the results when I do the first one.
#1180
Posted 17 January 2013 - 06:04 AM
well looky here!is there a guide to doing this? I am currently all stock, no 3rd party.Circles widget is not a stock item in jelly bean. It is stock item for some devices running jelly bean. The easiest way to get circles is use the razr m launcher which had the circles widget. Unfortunately the widget can't be used on a third party launcher as of yet, so you have to use the razr m launcher to use the circles widget.
