#1121
Posted 04 January 2013 - 03:17 PM
However, that not why I am posting.... With this JB version, there is a new icon I am sure you all have noticed which appears to the right of the 4G LTE icon and just above the cell signal bars icon when WiFi is enabled. It looks like a tiny house with concentric "RF rings" above the roof and it seemingly randomly blinks. However, the old WiFi icon is still there and it has little black up and arrows that indicate the occurrence of in-bound and out-bound traffic. The blinking of those arrows is not synchronized in any way with the blinking of the tiny "RF house".
Has anyone cracked the code for this new icon? Is it providing any new useful information or is it just a new status bar "noise source"?
- heleonardman likes this
#1122
Posted 04 January 2013 - 05:57 PM
Now, I want to go back ICS 4.0.4 by RSD Lite 6.1.4 with SBF file from
Thanks All.
#1123
Posted 04 January 2013 - 06:00 PM
My phone Droid Razr XT912 running 4.1.2 leak. But have some problem as: wifi, lost root..
Thanks All.
unless something has changed while i was napping..... you can't go back to 4.0.4 after updating to 4.1.2 .......
- Thach and caobmt like this
#1124
Posted 04 January 2013 - 06:01 PM
You are correct. There is NO going back to ICS.
HD Tappin and Talkin From my N7
- caobmt likes this
#1125
Posted 04 January 2013 - 06:22 PM
Thanks!.You are correct. There is NO going back to ICS.
Because lost root, I can't run Safestrap.
Now I find a rom can run in Stock Slot and install by motorola recovery.
Can you help me?
p/s: sorry, my English is bad.
#1126
Posted 04 January 2013 - 08:26 PM
First words in OP
- mattlgroff, fadeds and johnthehillbilly like this
#1127
Posted 04 January 2013 - 09:20 PM
Udate; Fixed--Matt is the DA MAN... thanks again.
#1128
Posted 05 January 2013 - 02:30 AM
what was the fix for removing SU? I am in the same situation.I was able to install the JB ota and keep root but now i need to unroot and send the phone back to VZ (sending me a new phone, Wifi and keyboard issues). I went back to stock recovery and reflashed the JB ota update(wiped cache) and it would appear im unrooted, however SU is still present and I cant uninstall it. Any Ideas?
#1129
Posted 05 January 2013 - 04:29 AM
Manually Team Viewered in and used adb shell to fix his root. My RestoreRoot would have worked though. MTP Mode. USB Debugging enabled.what was the fix for removing SU? I am in the same situation.
- johnthehillbilly likes this
#1130
Posted 05 January 2013 - 07:39 AM
Damn, thats an early morning post...
#1132
Posted 05 January 2013 - 08:16 AM
"Have drivers installed, phone connected, and USB Debugging enabled in Develope
r Options."
/system/bin/sh: /system/su-backup: not found
/system/bin/sh: su: I/O error
5758 KB/s (91992 bytes in 0.015s)
3550 KB/s (1020803 bytes in 0.280s)
"Rebooting..."
If the above id shows 0 then you are rooted. Press any key to exit.
I still receive I/O error when trying this. MTP mode and USB debugging enabled.
what can I do to remove SU? is it possible?
#1133
Posted 05 January 2013 - 08:52 AM
I have no idea what I/O error is. I have never seen it before."Have drivers installed, phone connected, and USB Debugging enabled in Develope
r Options."
"Rebooting..."
Open the RestoreRoot in a text editor and see what links to run manually.
#1134
Posted 05 January 2013 - 09:04 AM
#1135
Posted 05 January 2013 - 09:05 AM
leave it up to me to fubar beyond a simple fix. lolI have no idea what I/O error is. I have never seen it before.
I also noticed after I click the bat file the command says server not running?
#1136
sent from my JB RAZR ... tapadriving
#1137
Posted 05 January 2013 - 09:06 AM
It resets the adb server thats normal.leave it up to me to fubar beyond a simple fix. lol
#1138
Posted 05 January 2013 - 09:08 AM
#1139
Posted 05 January 2013 - 08:58 PM
Razor Unbrick utility...what was the fix for removing SU? I am in the same situation.
#1140
Posted 06 January 2013 - 08:30 AM
