1212 replies to this topic
#1061 kr8os71
kr8os71
  • 21 posts
  • LocationAustin, TX
Posted 30 December 2012 - 07:21 PM
Even though I love jb on my razr, I can't stand the fact that I lost root(by my own fault). What do you guys think: wait until someone finds a way to root jelly bean? or get replacement and root ics then upgrade to jb?
  • wabmorgan likes this
#1062 hawkz28
hawkz28
  • 12 posts
Posted 30 December 2012 - 07:49 PM
Wait. If it's like how the ics leaks were it will just be a matter of days....
  • kr8os71 likes this
#1063 dpratt23
dpratt23
  • 92 posts
Posted 30 December 2012 - 08:38 PM
I think if you really read most of the posts you would come away with the impression that this release is a good one. I can say that this is the best my phone has run since I got it and I've been on quite a few different ROMS so hopefully your install went well and you enjoy this erroneous release. I'm sure when the next one gets pushed it will be posted here immediately!
Maybe I am overly paranoid. I think this release is the tits so far personally. But your statements have put my mind at ease. Hopefully all will be well. Thanks fellas
#1064 dpratt23
dpratt23
  • 92 posts
Posted 30 December 2012 - 08:42 PM
If you follow the op to the word you will keep root. Update binaries on su as well.
  • mattlgroff likes this
#1065 Nitewolf
Nitewolf
    Member of the BEST android community
  • 643 posts
Posted 31 December 2012 - 04:16 AM
If you mean getting a "warantee replacement" because you simply lost root it might constitute warantee fraud, which is kinda frowned on.
#1066 foxisbubba
foxisbubba
  • 15 posts
Posted 31 December 2012 - 05:56 AM
I requested and received a replacement based on the accidental (as far as Verizon is concerned) release of JB. I did have some connectivity issues, but was more concerned with losing root and wifi tether hack... Now I am re-rooted on ICS on the replacement razr patiently waiting for an official 1 click root before I upgrade (due to my abilities lol)
#1067 Nitewolf
Nitewolf
  • 643 posts
Posted 31 December 2012 - 06:24 AM
OK gotcha. I would suggest using xlightwaverx's dual boot utility if you don't want to go down the upate leak path. You then have the ability to swap between the ICS kernel and JB kernel... Keeping your phone fastbootable.
  • wabmorgan and foxisbubba like this
#1068 dowens9603
dowens9603
  • 56 posts
Posted 31 December 2012 - 07:49 AM
I am having issues. I have done all of this to one rzr and it worked perfect. I did the same proccess with another one and for some reason I dont have root accsess. It is telling me no su binary found. I did everything exactly the same on the other phone and worked perfectly. dose any body have any suggestions? Or a way to root the new 4.1.2 from scratch.
#1069 DHA123
DHA123
  • 44 posts
Posted 31 December 2012 - 07:53 AM
Best any of our phones have ran since our bugless beast days on our og Droids- our prior phones.
Yes, we're the schmucks that hang onto a phone for 2 plus years
+1 some for more than 2 years....
#1070 noamparn
noamparn
  • 51 posts
Posted 31 December 2012 - 10:08 AM
Did you have root on that one before upgrading?
Did you make sure you had the latest superuser binaries?
Did you "temp unroot" and "restore root" TWICE before upgrading?
Did you try Matt's "Restore Root" utility after upgrading?
  • Shawn! likes this
#1071 jmaher1023
jmaher1023
  • 19 posts
Posted 31 December 2012 - 10:21 AM
I tried installing the update thru stock recovery from ext sd card and got "E:Error in /tmp/sideload/package.zip (Status 7)" now my phone won't boot. I can get into recovery, but no clue what to flash to get my phone working again. plz help!
#1072 cmh714
Posted 31 December 2012 - 10:36 AM
Sounds like u need to get back to Fastboot mode and try Matts utility again
  • jmaher1023 likes this
#1073 jmaher1023
jmaher1023
  • 19 posts
Posted 31 December 2012 - 11:00 AM
Whew! Matt's utility did the trick! I thought since I had started flashing JB I wouldn't be able to flash back to ICS. Could the error be because I didn't temp unroot b4 flashing?
#1074 Giblet535
Giblet535
  • 65 posts
Posted 31 December 2012 - 11:06 AM
Easy as falling off a log.
I didn't read beyond 'Download it here', yet managed to retain root via a manual backup (or three).
So far, my experience is 100% positive. A couple of apps FC, but I already expected that from running a Nexus 7... It's the same apps, too.
If I lived . I'd be ~ by now.
#1075 noamparn
noamparn
  • 51 posts
No, you're *not* supposed to "temp unroot" before flashing.
Did you follow his directions EXACTLY the first time you tried?
#1076 Nitewolf
Nitewolf
  • 643 posts
Posted 31 December 2012 - 11:08 AM
And no, you do not want to be Temp. Unrooted when you update.
#1077 violaian
violaian
  • 38 posts
  • Twitter:@violaian
  • LocationLas Vegas, NV
  • Current Device(s):Moto Droid RAZR
Posted 31 December 2012 - 12:44 PM
I followed all directions and still lost root :( Anyone getting close to a root method?
#1078 Giblet535
Giblet535
  • 65 posts
Posted 31 December 2012 - 12:47 PM
I assume that you've seen
#1079 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 31 December 2012 - 12:54 PM
Thanks to all involved here. My wife's Razr is updated with root...
  • satman80 likes this
#1080 kr8os71
kr8os71
  • 21 posts
Posted 31 December 2012 - 02:56 PM
the faith is strong with this one...
